Engine miss
Old Oct 24, 2004
mkober's Avatar
mkober is an unknown quantity at this point
Angry Engine miss
I have a 1989 CRX that me and my sons are restoring. It has developed a miss. I replaced spark plugs and wires but to no avail. A garage mechanic here said it could be a valve. I tested the compression and have 2 cylinders at 70 lbs. and 1 at 60 lbs. I have isolated the cylinder as I can pull the wire off the distributer. That cylinder has compression of 55-60 lbs. I can remove the wire and it makes no difference, however when a idle up it does. It does not run rough, just makes that puffing noise. It seems to me that if it was the valve it would get worse with higher RPM. Has anyone had this and can you give me a tip. Thank you.
Ninetyatecivic
May 9, 2015 07:48 PM
usajags84
Apr 10, 2015 09:54 PM
SoNiCcIvIc
Mar 11, 2002 03:37 PM
supercivic01
South
Nov 30, 2001 11:27 AM
viper775
Nov 8, 2001 01:58 PM
