check engine light?
Old Oct 22, 2004
AznChinksta's Avatar
AznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really nice
check engine light?
i just installed my injen short ram, should the check engine light be on?
Old Oct 22, 2004
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Disconnect your battery for 15 minutes (the neg cable) and that should reset your 'puter.
Old Oct 22, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
did u put ur air intake temp sensor back in??
Old Oct 22, 2004
its didnt have any electronics for the SRI
Old Oct 22, 2004
RallyeRed2k2's Avatar
RallyeRed2k2 is an unknown quantity at this point
when you took your stock air box off there was a wire you had to disconnect(air intake temp sensor), you should take the sensor out of the stock air box and there should b a hole in your SRI, you can use the same rubber washer from your stock box. If you dont have a hole in your SRI for it then take it out anyways and connect it and put it somewhere out of the way. Then disconnect your battery to remove your check engine light. If that doesnt remove it then autozone can remove it for you for no charge, just ask someone u have a light on and u have a OCB II connector.
Old Oct 23, 2004
Thx man i think this will help thx again
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
