Got my ingalls camber kit....
GODLIKE
Rep Power: 0 Got my ingalls camber kit....
So should it come with the 2 backs and all the bolts.....
and for the fronts....
should there be 4 bolts or just 2 (1 each side)
Rep Power: 445 ok your post was kinda hard to understand....anyways...what you should have are the arms for the back and 4 screws for them. 2 for each arm. And you might also get some bolt seperate for the arm to attach to that DRUM part i forgot what it's called.
then you get 2 bolts for the front.
TeLLy is my daddy
Rep Power: 0 laurence...uh oh, i heard ingalls aren't good..actually, i heard everything for our car with camber kits is bad except the hotchkis one's....u should have waited and checked dc5ab.com, cause they have a gb going
Originally Posted by wonderz
even the SPC ones are bad?
TeLLy is my daddy
Rep Power: 0 well from what i heard, ingalls were known to snap, it's happened to almost every car that ingalls made camber kits for...the screws just snap in half....or the threads give stripping the screws....this problem also applies to spc, but spc doesn't happen as often (so spc is better than ingall) but it also does happen to strip the bolts easily...
the only one's i've heard are actually "unbreakable" are the j's racing camber kits, or the hotchkis camber kits...everything else will break due to hard cornerings....
search around u'll find countless amounts of threads on ingall and spc and the problems people have had with them....
good thing about spc and ingall, they are affordable...
hotchkis is expensive, and j's racing...well, it's almost doubled the price of the hotchkis one's...
GODLIKE
Rep Power: 0 Ahhh crap.....man I thought that Ingalls was a good product.....man...I never read nething that said they were bad......man...now I don't want to install this kit..if it's gonna fall apart or even break....because I do corner hard......
So like will this break and then I will end up crashing my car?......Im very confused right now....
Because I got 4 boxes......2 for the back with all those parts.....and then 2 boxes for the front that hold the 1 bolt per box.....I'm confused as to how it should break....because the bolts that go into the body are the OEM bolts that are already attatched.....
Can someone find the threads that say ingalls is crap...and how it will mess my car...thanx....
TeLLy is my daddy
Rep Power: 0 i'll see what i can dig up for you, we actually started a thread on spc/ingall camber kits on dc5ab.com, u might wanna look that up, it's under gb's i believe...
but yea, i dunno if u know chris (Webxfx) he did a lot of research on the camber kits, and everyone that he's found is **** so far....but from what i'm hearing from other people, j's racing and hotchkis are suppose to be the best on the market, but costs an arm and a leg
as for hard cornering, i wouldn't suggest it...ur top camber kit holds ur wheels straight, if one of them gives, ur wheels will just fall flap on it's face, or fall into ur wheel well damaging **** inside (which i hope never happens)
Dave Brabant
20
10-06-2015 12:44 AM
beanhead
09-24-2015 12:04 PM
TheRiddicles
09-21-2015 01:28 AM
