top dead center, how do i find it? tdc?
Old Oct 11, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Question top dead center, how do i find it? tdc?
I am in the process of removing the head on my car because i blew my hg. I needs to set the timeing to top dead center, but how do i find it?
Old Oct 11, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
There are a couple ways to do it, if you have the head off, you can use a dial indicator and a stand, or use the crank marks.
Old Oct 11, 2004
SODJAZERO's Avatar
do you have more detailed info as far as crank points?
Old Oct 11, 2004
Yea, there is a mark on the crank pulley and a pointer on the block that you can line up. I don't remember the specifics off the top of my head but shoot me a PM and i'll check tonight when I get home from work.
Old Oct 11, 2004
HyaBoosta's Avatar
yeah it's easiest to just line up the marks on the crank pulley and use a wedge to hold it in place.
Old Oct 13, 2004
03civicdx's Avatar
03civicdx is an unknown quantity at this point
this is a pretty easy way to do it, get the engine put back together, pull the spark plug out of the number one cylinder, and take a piece of paper towel and roll it in a ball large enough to cover the hole where the spark plug is, have someone crank it untill the little paper towel comes shooting out, then take a flashlight and rotate the crank untill the piston is at the tdc youll know because it will obviously go back down if you go to far then back it off a bit, you want to make sure you have TDC on the compression stroke or you will have no timming at all but i wanna know how your planning on setting timeing on a car that has no distributor? the computer controls the timeing...
Old Oct 13, 2004
Don't forget the specs for the head bolt torque.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
GolNat
Suspension DIY
May 12, 2022 06:49 AM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
MajTom
Jun 2, 2015 11:48 AM
mievil
Apr 28, 2015 11:02 PM
