Engine Noise... manifold???
Old Sep 23, 2004
rzc's Avatar
rzc
rzc is an unknown quantity at this point
I had to get new tires and I noticed that there is a wierd noise coming from the manifold area when I only rev the car.
The dude says it may be my manifold gasket or the manifold itself.
What do you all think?
BTW, I have a 2001 LX Sedan with about 154k.
Yup 154k, besides this noise the car is still running excellent.
Old Sep 23, 2004
Could be just a loose heatshield on the mani that's rattling.
Old Sep 24, 2004
rzc's Avatar
rzc
I will try to look into it more this weekend and see if I can figure out the source.
Old Sep 24, 2004
Got Boost???'s Avatar
can you describe the noise?
Saying a noise comming from the engine doesn't give us much to go on.
Is it a short fast tapping? Or is it more of a thud? Does it sound like metal on metal? or is it an air noise?
Old Sep 24, 2004
ASIANPRIDE's Avatar
GODLIKE
ASIANPRIDE is an unknown quantity at this point
Exclamation
I have the same sound...I can't stand it....It doesn't come when I rev the engine but when I'm in first gear and slowly start to accel. It's a sound that works parallel with the speed of the engine at about1-2k rpm....The sound is metal and air tapping rapidly....And the faster u accel the faster it ....does it's muffled "dat dat dat dat dat".....Like is it my tranny??? Am I low on fluid somewhere...cuz I have done all my tune ups...but hell it's ****ing garbage....and soo noisey and it's getting louder.....I have about 80,000km on the car....
Old Sep 24, 2004
Aftermarket intakes alot of times will rattle. The fipk and aem both touch stuff and vibrate, but you can put foam in some places. I still get rattle when turning the car off.
Old Sep 24, 2004
ASIANPRIDE's Avatar
GODLIKE
It's my AEM rattleing? NO ****...
Old Sep 24, 2004
ASIANPRIDE's Avatar
GODLIKE
^Hmm not sure about the AEM....I think it might be something else...cuz its on pretty tight....But I tried it again and I got vibration or muffled tapping rattled noise from 1st gear up to 3-4k rpm and then 2nd gear at about 2-4k rpm....but once I accel faster you can't really hear it nemore...
Old Sep 24, 2004
rzc's Avatar
rzc
I only notice this when Im on idle then I rev the car. Sounds more like fast metal vibration.
Old Sep 27, 2004
ASIANPRIDE's Avatar
GODLIKE
Booo no help so far...
Old Sep 27, 2004
Logan3024's Avatar
you guys need to inspect your exhasut manifold for stress cracks. the top part of the lx manifold is 2 peices stamped together with very small shitty welds, took my someone i know about a year to figure out why his car sounded like a putt-putt ford.
Old Sep 27, 2004
Logan3024's Avatar
look at the top part of this header, the outside is a big weld, stamping the 2 together, look in the middle of the 4 ports, between port 2 and 3, that small line you see is actually a weld, the most likely where you leak is coming from
Old Sep 29, 2004
ASIANPRIDE's Avatar
GODLIKE
Some one said it could be the CVL joint...
Old Oct 26, 2004
dragilores's Avatar
dragilores is an unknown quantity at this point
So is there any solution to the sound? I am looking to buy an 03 Civic EX 5spd, but it has the rattling sound at low rpm and low gears. The higher the RPM the less audible it becomes. It is somewhere in the right part of the engine compartment... Wondering if it's anything serious, coz that's what puts me off from buying that car right now. Thanks a bunch..
Old Oct 26, 2004
dragilores's Avatar
btw the civic is used, with 53000 miles
Supramk3
May 11, 2015 07:55 PM
oqjoi
May 9, 2015 10:31 PM
ORskier
May 3, 2015 12:54 PM
mievil
Apr 28, 2015 11:02 PM
