Tools needed for header install ? ? ? HELP
Old Oct 20, 2004
V2Civic03's Avatar
V2Civic03 is an unknown quantity at this point
Alright so i attempted to put my new headers i got for free on my car
yesterday. Harder than i thought, YEA! how the hell do i get the bolts
off the old headers, there on the so fu*k*n tight. And how do i get to the bolt thats behind the power steering pump or whatever it is? this is pissing me off can someone who has experience with this help me out. What do i need tool wise, and some directions. You input is appreciated. Thanks!
Old Oct 20, 2004
Excal's Avatar
blah™
Excal is an unknown quantity at this point
your gonna get flamed for questions like these...Little advise search first if you really cant find it...then ask.
http://www.7thgencivic.com/forums/sh...header+install
Old Oct 20, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
best thing to get is some type of rust remover for bolts such as WD-40, to loosen the bolts
Injen
Old Oct 20, 2004
civicvtec1ps's Avatar
Search and Learn
Rust remover.
Torque Wrench.
Time.
Old Oct 20, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
[QUOTE=V2Civic03] And how do i get to the bolt thats behind the power steering pump or whatever it is? [QUOTE]
Not trying to be a jerk but...
It doesnt sound like you know what you're doing enough to be attempting this install. To get to the one bolt all you need is an extension. To loosen the bolts use WD40 and something to extend the handle of the socket wrench(like an extension with a 3/8" drive so you can fit it on the handle of the wrench for more leverage) Then you need channel locks or something to take the oxygen sensor out.
but seriously you may want to rething this and/or get some help.
Old Oct 21, 2004
V2Civic03's Avatar
[QUOTE=ohiojosh78][QUOTE=V2Civic03] And how do i get to the bolt thats behind the power steering pump or whatever it is?
Yea thanks for the consideration, but sorry im not a fckn retard, yes i know enough to do it myself. i tryd it with an extension i cant get the bolts to budge. ill try to WD40 though. thanks.
Old Oct 21, 2004
ohiojosh78's Avatar
Originally Posted by V2Civic03
Yea thanks for the consideration, but sorry im not a fckn retard.
LOL sorry, i wasnt trying to offend. It's just that some people arent mechanically gifted
Old Oct 21, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
WD40 sucks. Use PB blaster if anything. I use schaffers penetro 90 and it works wonders.
WD40 is a "water dispersant" not a rust remover.
Old Oct 21, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Try Liquid Wrench. Worked better for undoing my endlinks than WD40.
Old Oct 21, 2004
civictuner's Avatar
civictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trusted
ok forget the other peoples advice.. listen to me cause i done lots of swaps...
tools needed...
air ratchet if u got 1 or use a breaker bar
impact gun for the pipe bolts or again use the breaker bar
if using breaker bar also get a ratchet
torque wrench
WD-40
ok first get the WD-40 and spray all bolts then get the air ratchet or breaker bar and remove the header bolts(dont use the impact) now once that is removed u can use the impact gun on the rest of the bolts.. once you got them out wiggle the manifold out and the o2 sensors (if eqquiped) then put ur new header on. then staring from the middle out usin a air ratchet or a regular ratchet tighten the header bolts then get the impact u must use one on the spring loaded blots unless u got muscle the tigten everything.. after ur done torque to spec then ur done rev that motor and feel the HORSEPOWER!! never torque a header bolt usin a impact gun or air ratchet
Old Oct 21, 2004
PB blaster and exact fit socket for the bolts with ratchet. All it involves is loosening the bolts.The one in the middle holding the heat shield doesn't even have to come off.
Old Oct 22, 2004
V2Civic03's Avatar
No offense taken, just never worked on an import engine before. Im used to everything being so open and in easy sight. Thanks all for the suggestions. i guess i gotta go hook up my compressor, and get some stuff to spray on the bolts. Thanks again guys!
Old Oct 22, 2004
Excal's Avatar
blah™
Have you seen new cars now...my father-in-laws POS PT cruiser...there is noway to work on that thing its the worst engine i ever seen to try and work on and thats not a import.
My chevy venture i had was impossible to work on. I found imports easier to work on then newer domestics...well execpt german cars those are just terrible.
Old Oct 22, 2004
1320Racing's Avatar
1320Racing is an unknown quantity at this point
Where Are You From Maybe Some One Can Actually Go To You For Help!!
Old Oct 22, 2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
dude, there are like 6 bolts and none are near a power stearing pump. The bolts that you are having probs with are the spring f*%kers. they are hard to get off somtimes. you need to order new ones because 7 out of 10 times you will bend them getting them off when they are tight.
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
Myredjonda
Apr 14, 2015 07:00 PM
Maximus
Bolt-on Engine Performance
Nov 14, 2001 10:52 AM
