DIY: Tightening E-Brake
Old Oct 20, 2004
hustlelikem0fo's Avatar
I was getting my brakes done by my mechanic today and I asked if he can tighten my E-Brake cuz that ish was loose like a 2 dollar hoe. Well, he told me a way to do it myself which was so easy I started laughing.
The mechanic is Russian so they are used to doing ghetto stuff like this in Russia..... but ****, it worked! haha
ok
put your car in reverse and give it some gas so you start rolling backwards......let go off the gas so you just go into a roll.....now that the car is rolling backwards press that button on the e-brake and pull the ebrake up so the car comes to a stop.
thats it. this tightens you e-brake back to normal....... i did this today and its as tough as it was when i got the car. i'm not sure how long it'll last for but whatever haha
i dunno if any of you guys knew this but i just found this today and now that it worked so i thought iw ould share
Old Oct 20, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
Yeah, this would be the "self-adjustment mechanism." A simple ratchetching mechanism in the rear drum that doesn't work worth crap on my car. I had to remove my drums and adjust it with a screwdriver to tighten mine.
Old Oct 20, 2004
zen_master's Avatar
****. i gotta try this.
questions:
1. do we have to neutral the car once the car move before pulling the e-brake?
2. while pulling, is it neccesarry to push the button? can we just pull it?
3. how hard should we pull it? how fast? should we actually do it slowly and feel the stopping?
4. at what position should we stop pulling the e-brake?
5. should we repeat the process if we're not satisfied with the result?
lastly,
6. any risks?
BTW,
one should probably realize that there are two different mechanism of e-brake tightening system..
first, the rachet star system inside the drum.....this will likely tighen up the mechanism inside the drum....and adjust the position of the pad to the drum....
second, the e-brake line......which there's a DIY for it here.......now, this one apparently tighten up the cable which leads to the brake drum system...
one should also realize that if we tighen up the star rachet to much.....the pad will be to close to the drum....and while ur moving ur car...it'll IMPEND the movement...and also kill the pad much faster.......
comments?
thanx!
Old Oct 20, 2004
VietScouty's Avatar
VietScouty is an unknown quantity at this point
Hmmm...I didn't know that but I use my ebrake sometimes when I'm still rolling...but good stuff.
Old Oct 20, 2004
R1Style's Avatar
rolling backwards works but like zen master said, you could over tighten them and cause premature brake wear. I'd just tighten the cable... the easiest way to do it is to remove the console around the e-brake. Follow the cable and you'll see two adjustment bolts... just tighten them up a bit and you'll be good to go.
Old Oct 20, 2004
IrockCivics's Avatar
is this for auto or stick?
Old Oct 20, 2004
VTECTypeR's Avatar
Dam im gonna go try this out today
Old Oct 20, 2004
should work for both
Old Oct 20, 2004
abmerop18's Avatar
Jam out with your clam out.
word ill try this tommorow and report back
Old Oct 20, 2004
zen_master's Avatar
me 2
Old Oct 20, 2004
VTECTypeR's Avatar
will try in about 2 hours will let you know. Ill try some ebrake turns since its wet outisde too lol. Il let u know if the leverage is good enough
Old Oct 21, 2004
Caucasian.Asian's Avatar
yeah, i gotta do this also. mine is hella lose...it feels like it doesn't even hold sometimes...
Old Oct 21, 2004
was anyone succesful with it? just wondering if it worked for everyone who tried it cuz it worked for me
Old Oct 21, 2004
zen_master's Avatar
eh......dunno why, but doesn't seem to work for me..
i keep pushing the button though while pulling the e-brake up.....
or shouldn't i?
Old Oct 21, 2004
haven't tried it yet. i think i'm going to do it in the next hour or so when i leave...
Old Oct 21, 2004
R1Style's Avatar
I tried adjusting mine by doing the rolling backwards technique and I can't seem to do it either.
I'm just gonna take my console out and tighten the cable.
Old Oct 21, 2004
VTECTypeR's Avatar
I tried it yesterday. This thing does work at all. Just tighten it the normal way
Old Oct 21, 2004
dirtySAMURAI's Avatar
I log in from time to time
Didn't work for me.
Old Oct 21, 2004
I actually counted the number of clicks I heard when pulling the ebrake to the full engaged position: 13 clicks. Just...wow.
Old Oct 21, 2004
zen_master's Avatar
what the................
this is actually the problem which i asked to the OP, does he KEEP PUSHING the button while pulling the brake up??
if u can hear the click, that means that u DID NOT push the button! maybe that's why it didn't work for me..................
I pushed the button and pull it out while pushing it............
Old Oct 21, 2004
hmm, this is weird. it worked for me. do you guys jerk it up fast or slowly?
because you have to do it sharply.... just jerk it up quickly and hold it up until the car stops
Old Oct 21, 2004
zen_master's Avatar
oh man.
u gotta jerk it?
o..........maybe that's why...i did it slowly...
again, while PUSHING the button or not?
Old Oct 21, 2004
Originally Posted by zen_master
oh man.
u gotta jerk it?
no. you press the button in and jerk it up really fast and hold it up there until the car comes to a stop. if you pulled it up slowly then thats why it didnt work. you gotta jerk it like you jerk your.... nevermind
Old Oct 21, 2004
zen_master's Avatar
oh man..
wait, so you keep pushing the button while jerking it out?
just now i did...........erh....without pushing the button..................doesn't work either..
the last one, with pushing and jerk em.....erh...yeah
Old Oct 21, 2004
R1Style's Avatar
ok are we still talking about the e-brake or jerking off because I'm confused? normally when i masterbate, I do it fast.
As for tightening the e-brake... I held the button in and I yanked on that mother fvcker hard... I actually did it about 20 times and still nothing.
It might not be working for some of us because the self adjusting thing is adjusted all the way out.
Just tighten the cable.
Old Oct 23, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I'm not sure what to think about that? haha Sounds like something I would do.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
JohnnyBxo
Nov 12, 2015 03:04 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
blward6
Sep 16, 2015 05:32 PM
califcamper
Jul 21, 2015 10:34 PM
