04 civic ball joint/control arm replace
Old Jul 20, 2015
califcamper's Avatar
califcamper is an unknown quantity at this point
Hi,
replaced my control arm and also my ball joint today,
and to do it had to remove axle nut, rotor, and steering knuckle to get
at the ball joint.
Does anyone that did this know is there any special order of putting
it back together? I was wondering if I should tighten down the
ball joint nut before putting axle into place and tightening down the
axle nut? As I have it now, I already have tightened the axle, and everything
is tight but the ball joint and when I went to tighten the ball joint nut, it
just seems a little off center? maybe normal? If there is a special order in
doing this please let me know, I would appreciate it as always. You all are
awesome!
Old Jul 21, 2015
emich's Avatar
emich is an unknown quantity at this point
Re: 04 civic ball joint/control arm replace
No special order but putting the axle first is easier. Don't worry the ball joint can't be off center.
I hope your ball joint have this.
Old Jul 21, 2015
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Not to be rude, but you DO realize that the threaded stud on the ball joint moves. Just gently tap it (don't damage the threads) so its straight and you can fit it into the control arm. Checkout youtube by searching for civic ball joint.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
El_Spic
Apr 23, 2015 03:14 PM
thesushiboy
Apr 12, 2015 02:54 AM
veloce
Nov 10, 2001 01:19 PM
