Fiberglass reinforced bondo.
Rep Power: 0 Fiberglass reinforced bondo.
...how good is this stuff. Does it crack as easy as bondo. Has anyone used it for custom work. i am planning to use around my screen in the dash. Does it apply the same as regular bondo. Any info is welcome. Thanks
Yes, it's an Acura EL
Rep Power: 344 Do you mean bondoglass? I used some on an integra bumper I shaved and painted this summer. Works great, but I can't really compare it to regular bondo cause I've never used regular bondo. Just be careful to mix the right amount of hardener with bondo.
Hey, I know Drew22Mader, the man with the sickest whip
Rep Power: 254 The stuff I use is called West System Epoxy Resin. You can get it at any boat supply store. It is WAY stronger than fiberglass filler and You can mix it to any thickness You want.(ketchup to toothpaste). I use 405 Resin, 205 Hardner and 105 fiberglass filler.
durkinz
07-03-2002 04:33 PM
