Undo Battery Or Not
Old Oct 19, 2004
DowntownRicer's Avatar
DowntownRicer is an unknown quantity at this point
Undo Battery Or Not
Just a silly question, why do a lot of the installation instructions for parts tell you to remove the wiring from your battery and in all of the DIY's i see, they never talk about it. Just wondering because, if your not messing with any of your electrical equipment, why would you need to undo the battery? Also, if you disconnect it, when you reconnect it, do you have to idle the engine for a time or anything?
Old Oct 19, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
So you don't bump a wrench against something you shouldn't. Mainly against the exposed starter contacts.
Old Oct 19, 2004
R1Style's Avatar
Disconnecting the battery is just a precaution.... this way you don't blow any fuses or fry anything. It also resets the ECU... so if you do disconnect it... just let it idle for a couple of minutes afterwards then you're good to go.
robjcivic
Mar 12, 2017 12:10 PM
haloway13
Nov 6, 2015 10:43 AM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
msaeger
Sep 2, 2015 08:47 AM
