- interchangeable exhaust??? possible???
- removing the dash...
- replacement oem filter?
- Help on Cat back systems...
- Best 95 bucks I have spent in a long time!
- installing intake what do i do
- DIY black housings
- how hard to install a header? it looks very easy to me
- WTF: Coilovers
- Need advice for mods to leased Civ.
- Alarm Install Help
- Air Intake Question
- serious concerns...
- Cleaning the INJEN FILTER
- DRL off?
- painted headlights...
- ECU Wiring Harness Layout Question
- DIY: Dash Lights Part II
- tail light covers? pics
- help about the side pinstripes
- Coilovers
- help please.. i hate muffler guys
- Civic EX, Civic Si (Si-R), RSX suspension
- GC/Koni prob!!!!
- DIY is kinda slow lately.....
- apc front strut bar which intake
- How do i reset the radio code
- Springs for sale
- HKS Turbo Kit
- Please help! Changing dash lights???
- K&N Fuel Injection Kit?
- Auto LX Intrument Cluster in 5spd. DX? Yes.
- can a ex aem cai fit on a dx
- OBD III?
- getting behind a pillar to knock out a dent?
- New Exhaust / Reset ECU?
- WHat are these for?
- whos got a helms and a scanner and wants to be nice?
- Just traded my 2002 LX Coupe for a 2002 EX Coupe
- rs kit w/mudflaps??
- Cleared Headlights w/pics. Looks good.
- horsepower = 1/4 mile time
- clutch pedal travel distance too long
- ARGH! Water in my altezzas!
- Spring break in period.
- Neons inside the middle air vent
- how to install the bodykit without shake and stay firm?>?
- I searched.. i can't find.. HELP on rpms
- Tires/rims QUESTION 215/45/17 on a lowered 2k1 ???
- Ignore last post and answer this one
- NX kit question on if somthing dosnt work, like one of the solenoids??
- Help people with the upper grill
- Grill Repainting
- INSTALLING PROJECTORS? HOW? NO INSTRUCTIONS!!
- Frankenstien Swap???
- Anyone done this to their Auto?
- DIY trim finally done...
- new idea for DIY...
- koni/ground control graumet
- ATTN: Those that installed their KONIs...???
- what this noise
- new clutch
- I have a HUMONGOUS problem!!!!please help
- Sedan DIY hyperblinkers
- need help on LED washers
- DIY on headlamp black housings
- Installing New Trunk Springs - need help
- anyone know how Scissor doors are done on civics??
- The myth of the 80 shot N2O, feasible?
- Good drop look
- DIY Govenor Removal Needed.
- Installing a spoiler??? Anyone done it before.....
- Maintenance TIME!!!!
- DC Sports TCS catback install ?s
- 15w50 motor oil
- Adjust Throttle Cable??
- Hood Rod
- swappable parts
- Springs to eliminate wheel fender gap?
- installing apexi rev speed meter
- DIY CLEARING HEADLIGHTS??????
- Speaker Mounting Depth?
- melting or cutting plastic?
- OEM rims?
- Someone throw me a fricken bone here ...... someone with electrical experiance
- Question to IamLoki
- Air Conditioner Removal
- POWER WINDOWS ON A DX
- Taking out THE TAXOMETERS!
- Looking for a certain alarm, any peps knowing about aftermarket alarms look
- Wiring lights
- ecu wiring
- Brake pads
- prokit = camber kit??
- HP Racing Header w/ Hi-Flow Cat
- ROTATE TIME
- Blinker idea & need help
- Help with Ground-Controls!
- Racing with 5 speed???
- Tail Lamps for 2k2 Civic Si
- Popping noise after spring instalation???
- xenon front bumper...
- Adjusting throttle cable feedbacks
- Installed My Projectors
- Hard-Wire ??? From Mega DIY
- idea approval?
- Will new tachs on a DX reset the total milage.
- DIY Blue Interior Lights
- Non-Civic Help Please....
- The dealer words
- AWWW... noise maker!
- Help!!! xenon body kit install...
- 300 HP 2k1 Civic?
- Anybody upgraded their ignition?
- Air/Fuel Meter..which wire off O2 sensor???
- HELP!!2nd gear pops itself out and grinds.
- messed up DIY's
- Help on Tachs...
- Projector question
- How to relay projector lights?
- What is the difference? 215/45/17 or 205/40/17
- 17" Wheels + 2" Drop + Body Kit = Scrapeage???
- painting rear drums
- AFTERMARKET STEERING WHEEL HELP!!!!
- map lights
- map lights
- pedal sizes
- removed resonator.. could bad things happen?
- Shift boot Replacement
- Injen Intake
- Aftermarket Springs/Coilovers...Do I need Camber Kit?
- K2 HID Conversion help!
- Premium vs. Regular
- Throttle Cable Probs. . .
- blinkers?
- Strut Bar taht fits a car with Intake
- What Alarm Sys...........?
- Does anyone know the value of R1 the resistor you play with on the DIY hyperblinker>?
- cheap cold air intake
- Which Strut Bar is it?
- throttle body spacer
- matrix 4-2-1 chrome header?
- Rims question?!?!?!?!?!?
- rear bumper
- Need DIY short shift adaptor install
- Top Of Coilover Bottoming out on strut housing
- Need help removing rear quarter panel
- Replacing black door handles and side mirrors with silver ones
- Gotta have 17s
- Will this wheel size fit??
- Flow of stock exhaust vs. aftermarket?
- No amp with bazooka 6 1/2's???
- any one have tips for installing a liteglow neon kit? or DIY?
- AEM Bypass valve diagram question
- hood holder bar thingy
- Brakes!! Need advice
- grill mesh install???????????
- panic button reprogramming
- Spring Installation DIY Needed
- lead substitute
- CAI and California Emissions
- Going to Buy Springs soon...NEED HELP.
- Mississippi and surrounding states
- Custom Question????????
- spoiler = installed
- Installed intake and Check Engine light appears
- oil pressure port....
- 2002 civic hybrid question. . .
- Exhaust Question
- Clutch question
- Need advice..please respond!!
- "Tricked Out Trunk"
- Interior Paint (besides Foliatec)
- Rear Suspension Problem
- Do i have to buy new headlights or can i just take out the orange corner?
- Is it possible to tuck
- does anyone know if this shift knob looks good on the 7th gen civic?
- Was there ever a DIY for the spare tire relocation?
- tire ? for the experts
- turbo
- Is it hard to Install Lower tie bar?
- Urgent! Those who installed their Konis...
- Painting the trim on headlights
- Suicide Hood?
- Upper Grill?
- its kinda off topic but 2k2 cavileer (clear corners)
- will 2001 GC coils fit on a 2002 civic?
- E-Brake Adjustment
- Kumosport
- Respond to Question ASAP Please!
- Clear bulbs
- Questions regarding Rear Spoiler and paint
- APC eurotails question
- melting wires?
- Will a rim with a +42 offset fit my 2k2 civic si!
- To anyone who can help...
- front camber after installing koni shocks
- Line loc's / roll control ?'s
- how do u get a stripped nut off that pain in the a$$ place on header
- Grinding noise under front passenger seats?
- Racing Downpipe
- Manual Transmission Fluid
- Installing OEM Spoiler Question
- Engine vibrates a lot
- Smoking Tail Lights
- need help w/ revo
- For those who have installed rear camber kits.....
- Rims!!!!!!!!!!!!
- Think twice re: Sway bar 19mm
- I need DIY On reverse indiglo gauges
- 18 inch rims!!! will they fit!!! Please help me before i buy!!!
- K&N FIPK VS INJEN CAI VS AEM CAI
- HELP! Sway bar installation!!
- How do I take off the handbrake cover?
- Muffler installation
- How do you use change rear turn signal?!?!
- about turbochargers
- carbonfiber help!!!!
- Am I Killing My Clutch? PLEASE HELP
- OEM body kit and exhaust
- STOCK vs VTEC ???
- New...Had a quick Question
- Muffler Only(all show) Need Expert's Help Please
- Should I install my Coilovers Myself?
- Led Wahers $UCK!!!
- Tire Pressure Question
- Dynamat HELP!!!!!!!!!!!
- That Mega DIY Thread
- lowering my car
- front bumper lights..and acuras..
- how do u take aftermarket emblems off ur car
- ok to switch to synthetic?
- need car audio advice please!!
- Light BULBS
- 4 APEXi VTEC CONTROLLER USERS
- Whats a B-Pipe?
- DON'T DO THIS
- Replacing Interior Bulbs
- Question about installing underbody neons
- tuning
- Help R1 Coilover Install
- Does anyone have pictures of
- HP Racing 4-1 Header not welded right :(
- DC Sports header problem
- Fender Piece. please help
- How hard is it to clear your headlights?
- Need Some Help Fellas
- Blue Side View Mirrors??
- Nasty Window Coating after window goes down
