Auto LX Intrument Cluster in 5spd. DX? Yes.
I was going through the junkyard today and came across a wrecked auto lx 2dr. I didn't have a screwdriver on me so I haven't gotten it out yet. I know there's the PRND32 display that obviously won't work but can anyone see any reason why the other meters wouldn't work properly?
other members here have done the swap and it's worked like it should... though they used the right cluster for their transmission. i'm 99% sure it will work... BUT... i'm 99% sure that tach will be WAY off -- 8000 RPM is at the 2-o'clock position on the automatic tach, and it's at about 4-o'clock on the 5-speed tach... but, i suppose it's better than having no tach [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
if i were you, i'd grab the cluster while you can. even if the tach is inaccurate, you can fix it by ordering the 5-speed indiglo gauges from APC... cuz those will have the correct layout and cover up the PRND32.
also, if you do get the indiglos... make sure that you get the APC ones. i've seen a few other brands on ebay, that were "specifically for the 5-speed" and had photos of "the exact one you're bidding on", and they were nothing more than the automatic-style without the PRND32 thing.
<< other members here have done the swap and it's worked like it should... though they used the right cluster for their transmission. i'm 99% sure it will work... BUT... i'm 99% sure that tach will be WAY off -- 8000 RPM is at the 2-o'clock position on the automatic tach, and it's at about 4-o'clock on the 5-speed tach... but, i suppose it's better than having no tach [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
I don't see why the automatic's electronic tach would be off. The tach wire sends a pulse depending on RPM in both 5spd and auto cars. I'm sure you're right about the tach not sweeping the same distance but I just can't understand why the rpm would be inflated.
hondacivic0253
Sep 29, 2015 08:06 AM
Sep 27, 2015 11:33 AM
stank
Sep 16, 2015 07:40 AM
rayman009
Sep 12, 2015 08:30 PM
Bricoleur
Sep 9, 2015 12:23 PM
