PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. o2 senor help ASAP!!
  2. JET Performance ECU
  3. Honda Warranty Question???
  4. wierd noise from engine
  5. guess what i found out....
  6. Aftermarket Fog Light Installation
  7. where can I connect the remote wire from my amp?
  8. how can i ajust my hand brake!?!?!?
  9. need tunning help!
  10. What to cover when powerwashing engine bay?
  11. Question about HID bulbs
  12. ive searched but no one knows, i know its the o2 sensor wireair/fuel
  13. bottom grill...?
  14. what is a vtch controler!?!
  15. OEM Foglight bumper template?
  16. Could an Oil Cooler make much difference?
  17. Clear Corners & Bulbs
  18. projector headlights
  19. does the check engine light effect ur car performance?
  20. installing sedan taillights
  21. Help real fast! Dashlight fuse blew!
  22. The Oil Pan
  23. idle
  24. thiswhere is the throttle cable
  25. diy pics
  26. 2 questions in 1 RE: gauges
  27. custom or store baught exhaust?!?!
  28. 2002 canadian si 1/4times vs integra gs?
  29. What is a mass airflow sensor?
  30. Attn: Grey.......
  31. Oil lookin headlights
  32. POWER BOOST VALVE
  33. spare tire swap
  34. HELP!!!! messed up my car...again...SOS!!!
  35. return fuel system....
  36. Need ECU chip info
  37. Where can i buy the service manual ?? book or cd
  38. DIY: Booty Call
  39. headlight in projections
  40. Funky DIY: Strengthening car rack ᢠbubble gelatin
  41. door sound
  42. Is it possible to Re-Finish My Lower Grille
  43. removing dash around headunit...
  44. need info
  45. lights on fresh air, a/c, rear defrost buttons?
  46. dome light wiring question
  47. pleaseeee help
  48. Acura RSX Headlight (conversion) Do You Think This Will Work
  49. Clearing corner question...yes another one.
  50. Red Gauges?
  51. Queation: Bolt on Mini Turbos on cold air intakes?
  52. ac condenser question
  53. Weird Sound??
  54. DIY: Light Color change for mirror control, cruise control, and sunroof control
  55. How to remove gear indicator on automatic
  56. Suicide Hood
  57. factory spoiler
  58. To those who made a Flip flop trunk!
  59. Point of distributorless engine
  60. Painting Altezza Grill
  61. Does any one make a mount kit for the k20 swap?
  62. tin can filled with pissed bees
  63. who makes stock alarms??? honda?
  64. alot of problems with head lights need help
  65. last turbo question
  66. Headers 4-1 vs 4-2-1
  67. blinkers
  68. Civic Sir Engine
  69. White instead of amber bulbs ok?
  70. NEW AEM CAI V2
  71. Horn wiring question
  72. Injen CAI install advice
  73. How do i paint my valve cover...DIY link doesn't work
  74. Piaa fog lights question ??
  75. turn signal
  76. what paint do you guys use for your black housing?
  77. Adjusting Projectors
  78. When is the right weather to clear headlights?
  79. downpipe, exhaust set-up
  80. Need some help fellas: Maint Req'd and D light
  81. 01 Up Civic Headlights vs. Acura RSX Headlights (conversion)
  82. Ground controls install Question, please help :(
  83. do i need a torque wrench?
  84. Magnaflow cat-back. opinions?
  85. Anything i can attach to rear window to boost reception?
  86. What to use to cover off what to paint on headlights
  87. painting grill
  88. obx 4" exhaust
  89. Rear bumper repair
  90. does anybody have a DIY on the rear bumper removal?
  91. Intake potential
  92. Those whistleing sound?
  93. Limited Slip Differentials?
  94. Cleaning Header Surface Rust
  95. DIY O2 Sim at ECU
  96. Installing Apex RSM Rev meter, need help!
  97. What the #$#@ is that sound?
  98. o2 sim install
  99. Honda Civic Stereo Install Kit DIY
  100. head gasket
  101. Switched Ignition power wire
  102. turning back mileage
  103. DIY A/C off Defrosting doesn't work for me.....
  104. does any one have the DIY to De-Rattle your license plate?
  105. Injectors???
  106. What is a fair 60ft and 60mph time?
  107. Dash light info everywhere... What about LCD display?
  108. stock security system
  109. Bodys shops..
  110. SRS side airbags and racing seats......
  111. labor cost for airbag installation???
  112. O2 problem sim maybee?
  113. gauges?
  114. spark plug wires??
  115. help: interior paint
  116. Question about trunk?
  117. Converted my SRI into CAI! *PICS*
  118. How to remove 2002 civic ex gauge cluster?
  119. Lowering ?
  120. Does 100lbs = 30hp?
  121. what the f....
  122. lookTaking the front emblem off???
  123. Headlight Problem
  124. One Vehical Problem Solved
  125. Teins SS dampers and EDFC
  126. Front Emblem
  127. camshaft lift/duration shenanigans
  128. Stock plugs....
  129. fuel tech questions
  130. Air Cylinders
  131. Projector Fog up
  132. Flasher Load Balance Kit
  133. 127-horsepower 1.7-liter engine to 170-horsepower?
  134. hp header
  135. Want to run high wattage bulbs!!!!
  136. HX OEM Exhaust fit on an EX?
  137. DIY muffler install
  138. Should I start my car?
  139. What to do with a pair of ruined headlights
  140. Paint overspray
  141. HELP, how do i take this piece out???? (pics)
  142. K20A Swap ECU Question
  143. 2 members need help asap!!!!
  144. anyone know wat kinda bulb we use for projector lights?
  145. 2000 dx hatch springs
  146. Finished shaving emblems and removing pin stripes..
  147. What happened to the GroundControls DIY????HELP!
  148. ported, polished, decked question
  149. Just ordered GroundControls, Any tips??
  150. Upgraded headlight harness = brighter?
  151. removing the headlights
  152. Some interior painting/designing q's
  153. clutch burned out :(
  154. Check engine light
  155. foglight aiming
  156. Strange Noise from car, need help??
  157. BLOWN MOTOR!
  158. Converted my SRI into CAI!
  159. Turbocharging the Civic Ex 1.7L
  160. bottom engine damage
  161. stealing a 7th gen civic
  162. Injen and K&N filter bag?!?
  163. torque?
  164. RS Front Grill Installation help!!!!
  165. Crack open Altezzas????Anyone???
  166. DIY: 02 SI Hatchback Steering wheel bolted on to a 02 LX coupe!!
  167. how much hp diffrence between 1.7 and 2.0 engines?
  168. Can you adjust the vtec timing without a Chip?
  169. Custom Interior Question???
  170. Turbocharger Market Survey 2001-2004 Civic
  171. Need Help with headlights
  172. Paint thinner question
  173. Quick swap question (sorry)
  174. headlights?
  175. Too Many KM already...Unplugging the wire running to Odometer?
  176. how to color match if i wanna paint my interior
  177. did anyone ask honda
  178. help with maint requir'd lite...
  179. <*<*Major problem with Kaminari side skirts*>*>
  180. installing side skirts
  181. Adding a simple ignition kill switch?
  182. DIY for HYPERBLINKER...**DETAILED**
  183. Which computer upgrade is better?
  184. Air Bag question
  185. what paint code for the aluminum dash
  186. just got my pedal covers, no instructions :(
  187. Hollowing CAT
  188. OMG!!!!
  189. Turbo BOV needed?
  190. NEED HELP ASAP, Car wont start
  191. Revo Technica Short Shifter Rattle Problem Solved!
  192. k20 swap question
  193. Turbo...undoubtely an old subject
  194. DIY: Custom Water Spit (make ur civic pee!)
  195. I need Audio installation advice
  196. shootin flames?!
  197. JET Performance ECU where can i upgrade my?!?!
  198. how can i turn my head lights like this one?!?!
  199. pulleys and alternators
  200. Why are the RPMs high when the car first starts?
  201. Rust spot on the door..anything that will help get rid of it?
  202. Help: Convert ft/lbs to N/m
  203. DIY...Black Headlights
  204. POPULAR SCIENCE....tuning issue?
  205. Wing Shaking
  206. OEM cd player
  207. Please help me guys!!!
  208. Pop-up headlight washers
  209. DIY: blue/red/green/yellow center dash lights
  210. Engine Malfunction Light
  211. DC Sport Ceramic Header
  212. hose wont hold intake pipes together...
  213. 5% tint on the back and 20% in the front?
  214. malfunction indicator lamp still not turning off!!
  215. paiting calipers
  216. - - - - IS IT POSSIBLE? - - - -
  217. help i need to build a car
  218. SMELL after RUNNING CAR HARD
  219. Need some help guys (keyless entry problems)
  220. Grill
  221. sensor for the s-afc
  222. What are the best kinds of shocks for 2k1civic?
  223. ticking noise
  224. MAP sensor
  225. Need pics of tires and rims
  226. Throttle DIY trouble
  227. Return fuel system... A good question!!!
  228. A bunch of smoked tail lamp questions
  229. ECU- VTM & Vtec Signal Wire Questions
  230. positive crank valve
  231. TYC projectors... pls help...
  232. Question on JDM tail light for sedan
  233. BUzzing sound coming from intake...
  234. Need everyones help on this one
  235. water injection
  236. Bad clutch? help.
  237. Will aftermarket bulbs void warrenty?
  238. o2 Simulator again!
  239. I need help...
  240. k20 swap question
  241. side marker rust prevention
  242. this car is slow...
  243. DIY Short Shifter
  244. injen help please!!
  245. Question about the Apex'i V-AFC
  246. RSX-Type R Engine ??
  247. ppl with octane sides please help =)
  248. Dome Lights
  249. Quick question
  250. old Clear headlight question, ><
