ticking noise
Old Feb 7, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
ticking noise
My car has a little over 5000 mile on it and just changed the oil in it. It was making a ticking noise before and now after changing the oil. Any one elses eninge tick? Its not real loud but sounds kinda like a valve, but should nt be cause the engine only had 5k miles on it.I took my muffler off and havent replaced it yet. Would this cause it?
Old Feb 7, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
Yeah I hear the same noise out of my engine. I think it's pretty normal.. And I've got 18K miles already.
Old Feb 7, 2003
APRboy's Avatar
APRboy is on a distinguished road
No, i don't think not having a muffler would cause the ticking noise. I don't think it's serious though.
Old Feb 7, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I've never heard a Civic that doesn't tick.
Old Feb 7, 2003
player's Avatar
maybe its a timer to the start of the end of your car
Old Feb 7, 2003
1973's Avatar
1973 is an unknown quantity at this point
if it kinda sounds like a helicopter type noise that you only hear when the car is idling, then its just the normal operating noise of the pcv valve.....all civics tick.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 9, 2003
DathAnEteRnaLbBLuE's Avatar
DathAnEteRnaLbBLuE is an unknown quantity at this point
get your timing belt checked, my car did that same crap but when i accelerate it stopped
and then i found out my belt was breaking up, honda should check that for you for free anyway
Dathan
Old Feb 9, 2003
Elite's Avatar
Elite is an unknown quantity at this point
spark plugs?
Old Feb 9, 2003
bobbyd's Avatar
bobbyd is an unknown quantity at this point
That ticking noise you are all hearing is the injectors! That is all it is. You can hear the injectors clicking one and off is all. Nothing to worry about. All fuel injected cars do that.
Old Feb 17, 2008
megacivicfan's Avatar
megacivicfan is an unknown quantity at this point
Re: ticking noise
I was trying to search and figure out where the noise is coming from myself. I have 168k miles on mine, it started lightly at 100k miles. I replaced the clutch a couple thousand miles ago, and it wasn't anywhere in the trans, clutch area. I was thinking injectors, or pcv (both I have not touched on the car.) It doesn't make any noise when I engage the clutch in 1st gear, until I let off the gas a little, and pull a sudden vaccuum on the motor. It will then do it pretty much all the time in city traffic (low speed, lower gears), and I think road noise drowns it out ant highway speeds. I let the car rest for a while, and it does it again. My civic was much quieter when it was new all the way to 100k miles. If it's nothing, I can live with it, but If it's a sign of a problem, I'd like to nip it now instead of letting it grow.
Old Feb 17, 2008
Re: ticking noise
could just be the injectors or the valves tapping. have you ever had a valve adjustment? run some fp60 from lubecontrol.com in the gas, that will clean up the injectors after a while.
Old Feb 26, 2008
twiztedD17A1's Avatar
twiztedD17A1 is just really nicetwiztedD17A1 is just really nicetwiztedD17A1 is just really nicetwiztedD17A1 is just really nicetwiztedD17A1 is just really nice
Re: ticking noise
Dont wory about it dude its the infamous honda knock from being driven hard. they all do it, its from head wear (cam, valves, spring, ...ect.)
Old Feb 26, 2008
SEN_ONE's Avatar
SEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of light
Re: ticking noise
It's a bomb. They started putting them in when they realized that the cars they made last for a long time. They want you to come back more often to buy a new car. If the ticking turns into a beep, jump out of the car and run in the opposite direction. Hope this helps you. Good luck.
Old Feb 26, 2008
chkolny's Avatar
chkolny will become famous soon enoughchkolny will become famous soon enough
Re: ticking noise
^^can you really blame them though, they need to sell new cars somehow!
Old Mar 4, 2008
civics4everyone's Avatar
civics4everyone is an unknown quantity at this point
Re: ticking noise
Do you really mean 5000k miles......taking muffler off a brand new car....*sighs*...have you taken anything else off?
Old Mar 4, 2008
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
Re: ticking noise
you're probably hearing injectors.
for the second guy, ever do a valve lash adjustment?
Old Mar 6, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: ticking noise
5,000,000 miles? 5,000 kilometers miles? Anyway.......I had a ticking noise I could only hear when my window was down, and even more when I was driving next to a wall or something where the sound would bounce back. It turned out to be as stupid as a screw in my tire that was hitting the asphalt with every revolution. But I couldn't see it because there's no gap between my tire and wheel well. The other thing is the engine grade, you might want to try switching to premium or supreme (maybe) to get rid of any engine pinging.
Old Dec 5, 2008
siblackcivic's Avatar
siblackcivic is an unknown quantity at this point
Re: ticking noise
My 2002 si is doing the same thing. It has 112,000 miles on it. I took it to one mechanic who told me that it was the timing chain.
I took it to the Honda Dealer and was informed that they NEVER replace the timing chain. He told me that there should never be a need to replace the timing chain, that the only thing wrong with the car was that I needed a valve adjustment. Please help me. Can the timing chain be replaced?
Old Dec 5, 2008
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Re: ticking noise
My 01 does the same thing. I have about 75k miles. I too assumed pcv valve and plugs but after changing both it's still there. I also ran some octane boost to help clear the injectors and yep still there. I think I have pretty much narrowed it down to the valves as it kinda sounds like they are tapping. I only hear it at idle as I assume with increased rpm the sound of the engine drowns it out. Yes it's annoying but you get used to it. I wouldn't worry too much about it honestly, just turn the radio up a bit as that's about as cheap a fix you can get.
nirvanaguy
25
Oct 26, 2017 07:26 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
tooly145
Sep 5, 2015 01:05 AM
jpat21
Sep 3, 2015 11:32 PM
15EXCoupe
Jul 30, 2015 12:59 PM
