Anything i can attach to rear window to boost reception?
Old Feb 21, 2003
lapchern's Avatar
lapchern is an unknown quantity at this point
My AM reception wreaks...i cant listen to the sports radio [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Feb 21, 2003
Hedonism's Avatar
Hedonism is an unknown quantity at this point
i also want to know this. i can get nothing excepted the strongest stations
Old Feb 24, 2003
lapchern's Avatar
bump...
Old Feb 24, 2003
txtadik's Avatar
txtadik is an unknown quantity at this point
might be because of the tinting, well that's if you have any
Old Feb 24, 2003
Scott2055's Avatar
Scott2055 is an unknown quantity at this point
I have no tint and i seem to get in most of the stations around here[IMG]i/expressions/face-icon-small-confused.gif[/IMG] Maybe it's becuase i only listen to the strongest ones, but i get most of the local AM sprts stations in fine.
Old Feb 24, 2003
lapchern's Avatar
you guys think if i stick like 50 of those cell phone antenna boosters on my rear window it would help??? [IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 24, 2003
Connie's Avatar
Quote
[hr]Originally posted by: txtadik
might be because of the tinting, well that's if you have any[hr]
FYI tinting is on the inside of the window so I don't think it would hurt reception....
Old Feb 24, 2003
CarbonFly's Avatar
Quote
[hr]Originally posted by: Connie
Quote
FYI tinting is on the inside of the window so I don't think it would hurt reception....[hr]
My reception on on my radio was fine. UNTIL, I got my windows tinted. And now the radio picks up reception fine, until I turn on the defrost, then everything just gets a lot of distortion.
So it is possible to be window tint.
Old Feb 25, 2003
solar's Avatar
solar is an unknown quantity at this point
Quote
[hr]Originally posted by: FlyRiceRacer02
Quote
Quote
So it is possible to be window tint.[hr]
I bet the reason your reception is bad when you turn on your defroster is because the tint shop probably cut the defrost wire or antenna wire. The wire probably isn't cut all the way through but enough to short out your antenna. Window tint isn't the cause of your problems, I bet it was the install. My antenna works fine with window tint and the defrost on.
Old Feb 25, 2003
HRocket2k2's Avatar
HRocket2k2 is an unknown quantity at this point
i got no tint on my windows and everytime i turn the defroster on i get no radio reception at all!!!
Old Feb 25, 2003
CarbonFly's Avatar
Quote
[hr]Originally posted by: solar
I bet the reason your reception is bad when you turn on your defroster is because the tint shop probably cut the defrost wire or antenna wire. The wire probably isn't cut all the way through but enough to short out your antenna. Window tint isn't the cause of your problems, I bet it was the install. My antenna works fine with window tint and the defrost on.[hr]
My theory about it is that the tint has some metallic properties to it and this makes a current connecting the defrost to the antenna. This is what I think causes the interference. I don't mind though. I barely ever use my defrost, and if I do I just turn on a CD.
Old Feb 25, 2003
solar's Avatar
I have Titanium tint on my windows with no problems, if you have no tint and the defrost screws with your reception I'd take it to the dealer.
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
clockwerx
Dec 13, 2001 12:39 PM
BamBam
Dec 8, 2001 02:21 PM
