JET Performance ECU where can i upgrade my?!?!
Old Feb 11, 2003
2k1lxcoupe's Avatar
blingbling member
2k1lxcoupe is an unknown quantity at this point
does any one know where can i progam my ecu chip?!?! i got a a 2k1lxcoupe.....and will my speed governor be removed if i program my ECU?!?!?![IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 11, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Chespest place to get the JET ECU upgrade is through JC Whiney online. It will run you $229.00
You get it custom programmed to your mods and you fill out on the sheet
that you would like the speed govenor removed and your RPM's raised 1K.
You will now be able to cross the finish line at around 88mph in 3rd gear.
Also, if you plan on getting N2O this is not a good upgrade since the upgrade will advance your ignition timing to by 5 degrees .
Good luck.
Old Feb 11, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
Can the stock motor handle a 1k rpm raise?? Also shouldnt you wait until you have all of you mods so when you get a new mod you dont have to get the ecu reprogrammed?
Old Feb 11, 2003
kjgracing's Avatar
To answer both your questions at once...Yes
BTW do s search on jet ecu....this topic
has been covered many times.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
Uan
Aug 23, 2015 03:03 AM
JetsterDajet
Aug 16, 2015 01:56 PM
henrytn
Aug 11, 2015 10:01 PM
swaff39
Aug 11, 2015 07:16 AM
