Quick question
I Am The Chosen One
combustion engines need gas to operate, so as long as you have your engine turned on it will be using gas, not as much as if you were mashin the pedal though (increase rpm = increase gas usage)
DIY King
If you let your foot off the gas it closes the throttle plate, but then the ECU itself controls how much air gets past the throttle plate by opening and closing the IAC valve (Idle Air Control). It basically compensates for engine load while idling. If your A/C is on it'll raise the rpm's slighty for example.
Just Be
I see.. so if your coasting, and the downshift effect is turning the engine, then why does it need extra "help" (fuel) to turn the motor? Doesnt the wheels turn it alone? (while off the gas)
DIY King
I guess it doesn't, but if you're going downhill and you let off the gas and you take it out of gear (neutral), then the rpm's are at idle. That means the engine is still getting some fuel. Now, if you turn the ignition off. Then the rpm's fall to 0 and you don't get any fuel. Now try putting the engine in gear. It'll make the rpm's shoot up.
the engine needs gas at all times, providing it has been ignited which happens when you turn the key, the spark plugs fire in a sequence and with that spark is a spurt of fuel, which combusts or explodes in the cylinder and causes the piston to move which in turn gives you your engine power even when your foot is on the gas, so basicly if you turn your car on, set it in your driveway and dont' drive it, or just let it roll down a hill, about a 500mile long hill with no stops or turns or intersections, it will eventually run out of gas.[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
CraigW
Aug 18, 2015 07:06 AM
civic98?
Aug 13, 2015 01:32 AM
NoobyKid
Jul 13, 2015 07:53 AM
