MAP sensor
Old Feb 7, 2003
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
MAP sensor
Where is our MAP sensor located? (have serched)
Old Feb 7, 2003
atl01's Avatar
Is it true that honda map sensors can read up to 11 pounds of boost or is this on the older models and on hondata that say unsing a GM 3 bar MAP sensor boost up to 28lbs acheived. What is our's a 1 bar?
Old Feb 9, 2003
Elite's Avatar
Elite is an unknown quantity at this point
hmmm... try your owners manual, it should say it in there. I'm not sure, what do you need help with turbo setup?
Old Mar 20, 2004
dubz01si's Avatar
dubz01si is an unknown quantity at this point
the map sensor it located on the right hand side of your airbox
Old Mar 20, 2004
cdmx's Avatar
looks like a needle, plastic needle you pull it out
Old Mar 20, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
dont get confused with the a/i/t air intake temp sensor also on right of air box and a plastic lookin needle.
Old Mar 21, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
yea...the manifold absolute pressure sensor is on the airbox...riiight...
it should be somewhere on the intake manifold, cant tell you exactly where since ive never needed to mess with it.
Old Mar 21, 2004
Goku's Avatar
Goku is an unknown quantity at this point
the MAP sinsor is on the manafold and its maked MAP it to the lower right of the throtal body
Old Mar 21, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
The IAT is what is on the right side of the airbox (the "needle" as you guys put it) The MAP sensor is on the actual manifold underneath the airbox. Should say Denso on it.
circled in red: (stole the picture from the TB DIY and circled it)
Old Mar 22, 2004
cdmx's Avatar
oooops
I got them confused.
BootyDo
Jun 21, 2016 03:45 PM
jzhartman
22
Jul 23, 2015 10:42 PM
mistermenphis22
Jul 13, 2015 04:43 PM
aultman1990
Jul 9, 2015 08:27 PM
CivicsClass101
Jul 9, 2015 11:14 AM
