Clearing corner question...yes another one.
Old Feb 23, 2003
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Well, i tried to clear my corners for my sedan, but failed miserably. [IMG]i/expressions/face-icon-small-mad.gif[/IMG] that damn sedan glue is such a pain[IMG]i/expressions/face-icon-small-mad.gif[/IMG][IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]Anywayz. I was thinking about buying the 2k1 coupe lights, but do you guyz think the coupe ones will be easier to clear than the sedan ones. Cuz realli those sedan ones are a pain in the a$$!!![IMG]i/expressions/face-icon-small-disgusted.gif[/IMG] THanks guyz
Old Feb 24, 2003
cambo's Avatar
I wish I was asian
there not too hard. jus use like 4 screw drivers and 2 friends.
my method:
oven @ 200 degrees.
stick them in on foil for roughly 7 minutes
have one friend unclip the tabs on the headlights fast
stick them in the oven agan for 2 minutes,
use a knife or razor and cut around the headlight seal
have that same friend start pulling the headlight apart at the curved side and use screw drivers to wedge and pry the head light open. 1 screw driver every 2 inches apart or so, wedge 1 in, turn, have the 2nd friend wedge the other screw driver in, turn, and so on. continue moving along the seal.
shouldnt take that much time or effort.
Old Feb 24, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Use a heatgun my friend.
Old Feb 24, 2003
Xopher's Avatar
From: Crestview/Niceville/Destin/Ft. Walton Beach, Florida, USA
Xopher is an unknown quantity at this point
I used a hair dryer to heat up my coupe lights. But still, that black stuff is a pain! I had my fiance help pull apart the lights. I recommend having someone else around to help you. cambo's method sounds pretty good too though.
Old Feb 24, 2003
cambo's Avatar
I wish I was asian
hair dryer cut off to fast to be effective, so a heat gun is definitely the way to go if ur wary of the oven.
i use the oven everyday, so its nothing to me. jus don forget ur headlights in the oven, if you do decide to use my method.
took me and my friends 10 minutes of prying per headlight bcuz we stuck it in the oven a bunch of times.
Old Feb 24, 2003
duyaknow's Avatar
duyaknow is an unknown quantity at this point
You haven't even gotten to hardest part yet. The worst part about clearing headlights is taking that chrome part off to get to the yellow reflector. So scared of bending the plastic pieces because they might break. The other bad part is getting the black glue on the chrome. Hard to avoid when your edges are all covered with glue. I think some ppl clean off all their glue before removing the chrome part.
Old Feb 24, 2003
Xopher's Avatar
Oooh yeeeah. I got some of that black glue on the crome piece and I cleaned it off.. A bit too good. In a little spot on the top of the piece I had worn off the crome color. But, it's on the top of the piece and only recognizable if you look for it while looking over the headlight. Oh well, I'll have my projectors soon enough.
Old Feb 24, 2003
2k1lxcoupe's Avatar
blingbling member
2k1lxcoupe is an unknown quantity at this point
eat some rice and beans my friend!!!.......use ur muscle
once u have space to put ur 4 lilttle finger in there u just have to pull apart!!!..
Old Feb 24, 2003
BlueRevs's Avatar
BlueRevs is an unknown quantity at this point
hell ya a little elbow greese never hurts. Hell i tore mine apart before i had even herd of sticking them into the oven. So if you want to be a man about it then pull with all your strength. The assembly is strong enough to be able to pry apart with out breaking anything
Old Feb 24, 2003
Connie's Avatar
How did you fail? Did your ruin your lights or just not succeed?
Old Feb 24, 2003
2k1lxcoupe's Avatar
blingbling member
i just cleared my light this saturday....i scratched the crome a lilltle bit....BTW is jut a little scratch u can barely see it.....
just to let u know when u pulling the crome out there BE CAREFULL!!!!.....is not as easy as the DIY in here.....i took the hole day to get it clear!!!.....but is done!!
Old Feb 24, 2003
bickford05's Avatar
bickford05 is an unknown quantity at this point
mine diddent take long at all, it only took me like 2 hours... waht part took so long?
Old Feb 24, 2003
Spider883's Avatar
9K Redline Owns U
i have done 1 sedan and 4 coupes and have never had any problem.. it takes me 40 mins to do everything now
Old Feb 24, 2003
dragoon's Avatar
i've done a couple sets, and they take about 40-45 minutes for the coupes, but the one sedan i did was a pain in the [IMG]i/expressions/moon.gif[/IMG] , that one took about an hour fifteen. i put the oven at 250, and don't forget to take out the bulbs [IMG]i/expressions/laugh2.gif[/IMG]
Old Feb 24, 2003
sg2kca's Avatar
sg2kca is an unknown quantity at this point
because of my sedan headlights, i got silicone on my gap sweatshirt, (i like to get messy in style), part of the black housing on the right headlight melted cause I left it in the oven too long [IMG]i/expressions/laugh2.gif[/IMG] its my brothers fault, the left headlight aim is off, theres fog like crazy in both of them, I tried re-sealing them 3 times!! Ah well, I'm gettin projectors in a couple of weeks
Old Feb 24, 2003
rino's Avatar
rino is an unknown quantity at this point
a trick to pull the reflector out without hurting anything is to use tape and stick it to the reflector and then just pull it out. Just a thought.
Old Feb 24, 2003
sg2kca's Avatar
Quote
[hr]Originally posted by: rino
a trick to pull the reflector out without hurting anything is to use tape and stick it to the reflector and then just pull it out. Just a thought.[hr]
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG] it shows you've never cleared any headlights, you just can't do it that way.
Old Feb 24, 2003
2k1lxcoupe's Avatar
blingbling member
the only reason it took me so long because i didnt have the apropriated tools.......i tought was easy like it shows on the DIY. but i found out theres like alot screws..but u just gotta take ur time....
dlg1985
Jul 23, 2017 10:03 PM
Whitexj
Sep 30, 2015 02:04 AM
Sep 27, 2015 11:33 AM
ZoSoIV
Sep 17, 2015 07:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
