Check engine light
Old Feb 15, 2003
Hondasport01's Avatar
Hondasport01 is an unknown quantity at this point
Check engine light
How do u reset that again. Does anybody remember how thw DIY goes? It's not listed... I searched
Old Feb 15, 2003
robbclark1's Avatar
Retired suspension supermod.
Clint i don't think you can reset the check engine light, just the Maint. Required light. If the check engine light is on, you should take it in because something is wrong. You can try to reset the battery for that. Take the positive cable off for about 10 min then put it back on. That will reset the ECU. If the light was meant to stay on (meaning something is really wrong) then it will come back on. IF it was just the gas door thing, then it will most likely stay off. Give me a call if you need help.
Old Feb 15, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
maint light, turn off the car, hold the button for awhile, hold it and turn on ur car. next time search first.
IBTL
Old Feb 15, 2003
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
remove the negative wire from you rbatter... let it sit for 30 minutes... then hook it back up..
Old Feb 15, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
Quote
[hr]Originally posted by: iluvbritney
IBTL[hr]
no need to flame a member who has been here a year before you. If you read his question carefully, you would have seen he was referring to the
CHECK ENGINE LIGHT, not the maintenance light
Old Feb 16, 2003
clownprince's Avatar
Ricerus Maximus
When I took my intake off the other day I forgot to hook the sensor back up and that caused a check engine light for me. After I reattached it the light was still on. Since it did not need to be on any more the ECU recognized this and after so many ignitino cycles it rechecks and resets the light.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
