foglight aiming
Old Feb 15, 2003
jro's Avatar
jro
jro is an unknown quantity at this point
foglight aiming
i need help aiming my oem foglights. i've already searched, but i could find the answer to my question. i already know how to aim the lights...i just don't know to what level they need to be aimed to. any help would be appreciated.
-jro
Old Feb 15, 2003
Friedrice's Avatar
Friedrice is an unknown quantity at this point
You're supposed to park a certain distance from a wall, and aim them a certain distance from the ground, it should be included in the instructions the lights came with. Just don't aim them directly in the eyes of oncoming drivers, I hate that.
Old Feb 15, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
i think 10 feet from the wall then make it aim directly at the wall
Old Feb 16, 2003
Bellz's Avatar
Google is a wonderful thing.
After using 'ol Google, I found the instructions you need at the Tire Rack. I've quoted them below for you.
You can also check out PIAA's instructions here.
Quote
[hr]Auxiliary Fog Lights:
Typically, fog lights are mounted under the front bumper about 10 to 24 inches from the ground. There are two important issues to address when installing fog lights, the first is to minimize the amount of glare that returns to the driver's eyes, and the other is to minimize glare into oncoming driver's eyes. Both must be accomplished while putting as much light as possible on the road.
These fog light aiming instructions are suggestions taken from common practice and the Society of Automotive Engineers (S.A.E.) standard J583. Some modifications to these instructions may be necessary to minimize glare.
Park the vehicle 25 feet from a wall on a level surface. Measure the distance between the center of the auxiliary light and the ground. Place a horizontal mark on the wall at that height.
Visual aim is made with the top of the fog light beam 4 inches below the lamp center at 25 feet with the lamp facing straight forward.
Auxiliary Driving Lights:
Typically, driving lights are mounted above the front bumper about 14 to 30 inches from the ground to provide extra high-beam illumination. Driving lights can be mounted below the bumper, although they will not be as effective because the light will hit the ground sooner and reduce the range of the light.
Visual aim is made with the center of the driving beam hot spot 1.5 inches below the lamp center at 25 feet with the lamp facing straight forward.[hr]
Old Feb 16, 2003
jro's Avatar
jro
awesome...thanks so much for all your help
-jro
Fern
Jun 10, 2002 06:04 PM
angjc3
May 29, 2002 03:57 AM
blouisgod
May 27, 2002 08:02 PM
angjc3
May 9, 2002 11:13 AM
Snowman
Feb 15, 2002 08:58 PM
