installing sedan taillights
Old Feb 25, 2003
ziggyziggy69's Avatar
ziggyziggy69 is an unknown quantity at this point
i need to install taillights for my 2k1 sedan this weekend. i did a search but i still dont understand. i know that the sedan is tricky because of the bolts behind the bumper. Can someone please post detailed instructions from removing the original lights to putting on the new ones and misc. steps like silicone and waterproofing. Thanks. Pics would be useful too.
Old Feb 26, 2003
LiKEaFeRiO's Avatar
The inner lights are real easy to take off; 1 nut in the middle and 2 others on the ends. Thats it.
The outer lights are harder. Heres how to take them off.
1. Remove 2 plastic clips from the bottom of bumper.
2. Remove 2 screws (4 total) on each side of the bumper, right behind the tires.
3. Open your trunk. On each side near the trunk lining you'll see 2 taps you can pop out.
There are 2 bolts to take off.
4. You should be able to take off your bumper now. Don't worry about using some force it's all held on by clips now.
5. Below the tail lights, you'll see brackets attached to the car with 2 bolts on each bracket. Take them off.
6. Now on to the inside of the trunk. You have to pull back the material thats preventing access to the lights. Before you can do that you'll need to unscrew the 2-3 clips that hold it in place.
7. Now you should be able to pull it back and you'll see that the outer lights are held on by 3 nuts.
8. Remove the brackets from the stock lights (1 screw each) and put them on the new lights. Some people didn't do it when they put theirs on. So I guess this could be an optional step.
9. You should now be able to just reverse the instructions so put everything back together.
For siliconing or waterproofing, go buy some clear drying chaulk at your hardware store and use as needed.
Old Feb 26, 2003
bluestreak's Avatar
bluestreak is an unknown quantity at this point
if you're lazy like me and have a really long phillips screwdriver, an open ended wrench and long arms, you CAN do it w/o taking the bumper off, it's more difficult, but I've done it before - D
Old Feb 26, 2003
smoke4's Avatar
The Dude
yeah i did it without taking bumper off too. its not that hard, but a flashlight helps seeing that screw from underneath bumper.
Old Feb 26, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Locked
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
robbie374
Jul 7, 2015 02:56 AM
Spanky4269
Jul 5, 2015 09:40 PM
Ilikemscruffy
Jun 26, 2015 09:51 AM
TiggerDX
Jun 18, 2015 01:43 PM
