bottom engine damage
Old Feb 14, 2003
chefjnr's Avatar
chefjnr is an unknown quantity at this point
for those of you that read my previous internal engine damage post, after removing the oil pan and looking into the engine, it turns out I did not break a rod in my d17 engine, My main crankshaft bearing was toasted. The thought of my mechanic was that the aluminum cradle allowed a little flex and that helped with the bearing geting smoked. I only have a NX 50 shot installed, is it possible that a 50 shot was too much HP and compression and did the damage to the bearing or do you think it was just bad luck in my case? I'm gonna pull the N20 system out and bring it to honda and see if I can get warranty coverage, I doubt they will pull the head and look at the pistons for signs of N20 as long as there is no trace of the system ever installed- what do you guys think? It will cost me $200.00 to remove the N20 system VS. $1200.00 for out of pocket repair. If it is covered, after I get my car back is there anyway to strengthen the bottom so this will not happen again, whether it be due to N20 or any other reason that would contribute to bearing failure? I spoke with some performance engine shops and they said that even engines that are built to hundres of horsepower use the stock bearings that the original engine came with. Your thoughts please
PS- I know the situation sucks, don't lecture about N2O and inevitable engine damage!!!!
Old Feb 14, 2003
cambo's Avatar
I wish I was asian
maybe u just sprayed at the wrong time [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 14, 2003
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
oh wow i was thinking about puttin my car on the bottle but now im scared to.. hmm i doubt honda will repair ur car cus i guess under normal circumstances ur engine wouldnt blow up like that.... i dont know much about this stuff but thats what i think i could be wrong tho.. good luck with all that
Old Feb 14, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
gee, i havent seen anything like that before
Old Feb 14, 2003
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
ouch.i'd remove your n2o system completely and bring the car back to the dealer.its gonna cost alot.hopefully they will put it on warranty.thats what i did in my situation.the mechanic told me later when it was fixed that i couldnt bring it back for any engine warranty cause they knew i was running n2o.[IMG]i/expressions/face-icon-small-frown.gif[/IMG]oh well a least it didn't cost me.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
thana
Jun 15, 2020 07:05 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Dmitri
123
Oct 13, 2005 08:01 PM
