O2 problem sim maybee?
Old Feb 19, 2003
VTECHUNTER's Avatar
VTECHUNTER is an unknown quantity at this point
allrighty then, so i put on a 4-1 header two weeks ago, of course i took my cat off.....i have no 02 simu;lator yet...just the 4-1 header...pipe and a muffler...the new header had one o2 fitting. so i just totally disconnected the second 02 sensor. the check engine light came on, i knew it would, it rean very well up untill this afternoon....the engine can barely run with out stalling out and the air/fuel meter is going back and forth betwen rich and lean VERY fast...i mean VERY fast, not like it usally does., do i just need a 02 sim for the second one....or should i just plug in the second one and tie it up somewhere....any help is greatfull! [IMG]i/expressions/face-icon-small-smile.gif[/IMG] by the way...its a 2 door lx 5speed
Old Feb 19, 2003
Tony4380's Avatar
Tony4380 is an unknown quantity at this point
hey man...which columbus? GA or OH? Im in GA......anyways....find a way to mount that second o2 sensor in the header.....you could burn up your engine if it runs too lean for too long.... and if it runs too rich too long youll have a nasty carbon build up and lose the HP you gained by the headers.
get it done right the first time......[IMG]i/expressions/face-icon-small-nono.gif[/IMG]
you can tie it up some where...but youll probably run rich.... so its up to you
Old Feb 20, 2003
VTECHUNTER's Avatar
ohio
carbon buildup- on the plugs? would that create the problem i was describing?
Old Feb 20, 2003
spike's Avatar
spike is an unknown quantity at this point
Just buy an O2 Simulator. That's what I did, and I have not had any problems yet.
Old Feb 20, 2003
VTECHUNTER's Avatar
i went out this morning and reset my ecu pluged in the second 02 sensor and zip tied it up...fired that sob up and everythign looks fine! ??? the air/fuel gauge is reading perfectly fine.....i hate all of this obd-ii bullshiznit!
if anyone has any questions go to www.obd-ii.com
Diznavis
Jan 25, 2002 11:25 AM
delacampos
Transmission
Jan 2, 2002 02:06 PM
02CarbonCivic
Dec 27, 2001 08:02 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
