PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. Valve Cover Temperature (Not the Wire Cover Noobs)
  2. throtle cable
  3. turbo
  4. blue headlight
  5. Okay quick battery issue, PLEASE HELP Me!!
  6. valve cover breather question
  7. Seatbelt question...
  8. More Grounding Kit Install Pics (56k Warn)
  9. Computer Upgrade?
  10. Anyone ever reuse the OEM shift boot?
  11. DIY: Ported exhaust manifold gasket
  12. K&N cone filter question
  13. Removing the Cat bolts?
  14. Fuel injector cleaner interval?
  15. is a 2003 ecu the same as the 2001/2 ecu
  16. Vaccum Lines
  17. Vtec Engagement??
  18. how to install 5" tachometer
  19. anyone have mil iliminator installed on high flow cat ?
  20. dimensions of stock intake breather hose
  21. removing stock headlights
  22. re: i need some help
  23. Back To Honda Again
  24. anyone have pics?
  25. No parts for the 2004 model?
  26. O2 Sensor - Diagrams
  27. headlights don't light up
  28. jack points
  29. Sub frame?
  30. need help with diy flip flop trunk
  31. Leaving out airbox???
  32. Required Maintenance, What Should I do?
  33. APEXi Turbo Timer
  34. Apexi V-AFC II
  35. Help, Keyless Entry Messed up
  36. Breaks
  37. Wiper Fluid Warning Light
  38. manual/auto center console question
  39. Need HELP with the MOMO steering wheel install??
  40. how to replace this molding?
  41. How do you tell if ?
  42. malfunction indicator lamp
  43. removing rear deck.
  44. MOMO Steering wheel Install Question?????
  45. porting exhaust manifold?
  46. What the hell is this noise?!
  47. Need help ASAP - 1.7L noise
  48. Paint Removal....
  49. Big Josh MIL Elim Wiring?
  50. hahah got $3 cone filter... now what?
  51. Are there really any hp gain in any engine mods?
  52. My AC smells like Cow sh!t!!!
  53. power steering removal?
  54. lx header
  55. exhaust manifold install
  56. Oil Light problem
  57. removing mud guards
  58. 96-99 question
  59. SRS light... already did the DIY SRS light
  60. Valve clearence adjustment...do or dont...and when?
  61. shift knob question
  62. throttle body heater bypass
  63. Yes I have searched it...
  64. Right hand Drive conversion
  65. Civic SI Ep3 Front Seats and that 4th bolt
  66. Help Needed!!!
  67. !!!!newb In Need Of Help!!!!
  68. Anyone know the part # for this!!!!
  69. blacked out taillights
  70. The Myth that driving faster uses more Gas
  71. Wash windows befor tint?
  72. Mini Me with D17 Head??
  73. 2001 Civic alternator belt adjustment
  74. Evo 5
  75. HELP!! Please.
  76. Eccentric Finger ??
  77. Unorthodox Crank Pulley
  78. Coolant
  79. bodykit install/fiberglass molding
  80. muffler madness
  81. Would this (from ebay) fit in our cars?
  82. which is better?
  83. did i mess up bad and how do i fix it???
  84. how much power steering fluid do i need for reflush??
  85. Question about cooling system?
  86. paint supply
  87. I read the DIY for the dash, is it all really necessary?
  88. WTF - D17A from japan on ebay....
  89. Reprogram your ECU for only $900....
  90. IAT Sensor
  91. ABS plastic question
  92. Are our cars being monitored (black box)
  93. URGENT Help! EBC Rotors + EBC green stuff pads
  94. Fuel and Vacum Lines...
  95. electrical switches
  96. Remote Start Problem! HELP!
  97. maintence light is on
  98. Cam Gear
  99. Taillight tinting question.
  100. Removing tint????
  101. Side Airbags?
  102. Internal Parts
  103. Need an ecu NOW
  104. m3 mirrors(help running led wires)
  105. DIY:01-03 Headlight Aim Adjustment 56K WARNING
  106. clutch diy?
  107. My friend has a problem w/ starting his car
  108. header to exhaust match
  109. sway bar links
  110. Bad Throttle responce HELP!!
  111. Oil Pressure Gauge Fittings - Need Help
  112. need help
  113. Here we go again
  114. rsx seat install questions
  115. Quarter mile times?
  116. 2k2 Short Shifter
  117. HP header and O2 sim. question
  118. M3 Mirrors
  119. Help with DIY Turbo set up...
  120. Spoiler Install
  121. TRUEHONDA.com
  122. Hondata For D17
  123. socket size of rotor bolt
  124. Fawked up my dash!
  125. car running sluggish, plz help!!
  126. aem intake diameter
  127. Help me with octane!
  128. some help w/ wiring indiglow shift knob
  129. lowering the stock seats any more?
  130. Tricked out trunk
  131. Aftermarket Sunroof
  132. how to reqire wire harness for new gauge cluster
  133. Shifter is out of wack.... Read please, searched....
  134. Checking oil, trans fluid
  135. header with stock piping and muffler?
  136. Truth about performance crank pulleys
  137. How to Remove B pillars?
  138. kamikaze header do u have modifications
  139. Automatic Transmisson, car throw in reverse while moving forward
  140. headers
  141. exhaust question...........
  142. DIY: Dash Removal
  143. A/C belt
  144. MIL Eliminator DIY
  145. mil eliminator universal?
  146. Help with header install!
  147. Flywheel removal
  148. Custom Intake?
  149. Hx to Ex Will it be noticeable
  150. F'd up car
  151. This should be a quick No answer, regarding a Head Swap D17 Mini Me?
  152. CEL goes off again!!!
  153. DIY Black Housing Headlights
  154. Fuel System Evaporation!!!
  155. Would removing the divider in the air filter housing...
  156. Alternator belt. Help please!!!
  157. graphics kit removal
  158. Dash Painting(not trim pieces)
  159. OBX Header
  160. DIY mirror help
  161. Can I have some opinions please?
  162. DIY Painting Interior
  163. Taking out passenger airbag??
  164. Going back to my stock air box...But...
  165. Nawz
  166. Getting Rid of Interior Neon Cigarette Adapter (connecting to fuse box?)
  167. Civic Alternator
  168. Does anyone know the weight of the stock flywheel??
  169. need help to install a tachometer
  170. How to activate Day Time Running Light
  171. can na civic be fast?
  172. If I wanted a switch... electric guys, please read.
  173. Things To Know Before Tinting?
  174. Does the engine clear the tranny
  175. anyone have DIY rear bumper removal?
  176. Can someone help me with my exhaust rattling problem?
  177. engine type
  178. Rotor minimum thickness
  179. stock throttle body question
  180. Alignment (Help!!)
  181. DH race pulley
  182. Off the line accelleration between LX and EX
  183. off the line accelleration diff between LX and EX?
  184. fix shield?
  185. tsunami front bumper
  186. Megan Racing High Flow Cat!!!
  187. Auto Transmission
  188. HX to LX Swap???
  189. Exhaust?
  190. i feel dumb...
  191. What is the proper way to relearn RCM/PCM idle
  192. 4 to 5 lug convertion.
  193. taking off headlights w/o removing bumper?
  194. Sedan/Coupe Headlight Assm. Difference?
  195. How to disable VTEC kick-in ALLTIME to save gas
  196. Build up automatic tranny or manual swap?
  197. Original ride height for Si(Ex) models.
  198. What would be the best way to paint these wheel areas?
  199. Vtec or not Vtec? that is the question
  200. Autometer Oil Pressure Gauge?
  201. maintenance required light
  202. Oil cooler install????
  203. How To Remove a Rusted Screw?
  204. DC5 steering fit our cars ??
  205. how to fit universal sliders in my car?
  206. quick question
  207. Changing the oil (first time)
  208. Setting the timing?
  209. Hood vibration: caused by cushion hood?
  210. Just Did the DIY VTEC LIGHT!
  211. synthetic back to dino
  212. Some dyno sheets- before and afters
  213. Spark Plugs, WTF
  214. Help solve a mystery shifter problem
  215. how much for lamborghini doors
  216. Should I get rid of the resonator?
  217. installing gages
  218. AC Belt removal
  219. Integra Seatbelt Question
  220. removing fender/wheel well?
  221. rsx seat install, version beta 1.0a...
  222. HELP w/ SAFC2
  223. So, whats really so special about Honda?
  224. HID help(projector don't bother)
  225. wooohooo! VAFC2 installed!
  226. Detonation???
  227. CVT tranny -Dont understand...
  228. Cold Air Intake Systems Installation
  229. V-AFC2 problem!
  230. K&N FIPK vs K&N Typhoon
  231. Greddy EVO II Install
  232. moisture in headlight assembly
  233. Tranny problem...has this happened to anyone else?
  234. Buddy Club Piggyback and VAFC2
  235. sidemarkers .. easy or hard ???
  236. Removiing the torsion bars
  237. Jdm Headlights??????
  238. Stretching sound from rear drum brake?
  239. Oem airfilter housing crap!
  240. Clearing Headlights, need help in NYC
  241. Amsoil Dealer told me..
  242. I need help so bad!
  243. how to install projector Light ???
  244. Is it a Sunroof or a Moonroof?
  245. How can this be possible? Exhaust sound-
  246. needle removal/LED info on 03+ coupe AT gauges
  247. Have question about swapping out exhaust?
  248. any hope in automatics
  249. Anybody heard of a VTEC-E?
  250. cutting stock shifter????
