HELP!! Please.
Ok sucky day. Miss passing my Microsoft XP cert by 13 points. But now for the real problem. I got my random tech high flow cat. I was putting some new bolts in for the top (Thanks djmota). Was working like a charm got both bolts started. Then started to tighten down the bolts. One of the bolts snapps off in the hole.
I was like ok. Everything will be fine. I will take the header off and use a tap to drill out the part that is stuck. I start loosening the bolts from the header. I get to the last nut (the one of the driver's side that is a pain to get to) and it wont budge. So I grab my little ball pin hammer and start tapping on the wrench. Tapping turns in to some force and just when I think it is about to break lose the whole thing gives and strips the nut.
So now my cat cannot hook up to my header cause there is part of a bolt stuck in the hole and I cannot get the header off because of one nut.
Any ideas? Please guys help me out. I guess I was just not ment to do anything important today.
Any ideas? Please guys help me out. I guess I was just not ment to do anything important today. Last edited by Toaster; May 3, 2004 at 06:01 PM.
I found these doing quick search of the net. Anybody tried using these?
http://www.sears.com/sr/javasr/produ...id=00952162000
Re: HELP!! Please.
Any ideas? Please guys help me out. I guess I was just not ment to do anything important today. If the car is driveable I would take it somewhere and have it done. It should only take 5-10 mins.
Bolt out worked great. Tried to drill out bolt. Snapped two bits. Tried to use an easy out snapped it twice. Finally knocked everything out with a tap and hammer after snapping my tap. Had enough of a tap left to retread. I put new higher grade bolts in no problem even bought a nut to put on top just in case the treads do not hold after all that.
h4ldol
Apr 24, 2017 08:16 PM
granny828
Jun 26, 2015 10:36 PM
woohooh00
18
Jun 28, 2002 08:28 PM
