porting exhaust manifold?
Old May 7, 2004
As you know, I've got the DH ported head. Now I'm going to try and port match the gasket and header (it's an HP replica header I believe) to match the head ports. Anyone have tips for me, or if this will work? I've never used a dremmel before. Thanks for any info.
Old May 7, 2004
djmota's Avatar
this is the way I did it. You just have to be a little carefull. and have compressed air handy to clean the mess.
Lay the gasket on the head, grind away and match it to the ports on the head.
(It helped me to take off the rivets on the gasket and seperate the 2 halves, so I could get inside and de burr the gasket on both sides)
de burr the gasket on both sides of both halves. and use compressed air and a q tip if needed to clean out the nasty metal shavings in the exhaust ports.
then get some contrasting spray paint and a few bolts and nuts, bolt the gasket to the header. Spray, let dry and remove. now look at the header and grind away/smooth out the painted areas. thats it. Mine has no leaks.
A paper gasket would have been much easier.
Old May 10, 2004
hooter73mc's Avatar
hooter73mc is an unknown quantity at this point
never heard the paint thing, great idea though. He said it, that's the best way...I need pnp...anyway.
Old May 11, 2004
skarteez's Avatar
skarteez is an unknown quantity at this point
hey hows that new head holdin up gearbox? i thought it wasnt workin out for you...
Old May 11, 2004
PacSmalls's Avatar
PacSmalls is an unknown quantity at this point
what is de-burring?
hey gear when you do this take lots of pics, make it a diy! im interested in learning
Old May 11, 2004
Project2k2's Avatar
Spray painting does sound off but makes sense. Are you sure that paint on the gasket would be a good idea? This might be the way I will do it. All I know is that it's gonna take a pretty good amount of time to get this all done. Bah.
Old May 11, 2004
I'm trying this tonight. Already bought a dremmel and have a plan I guess, so hopefully nothing bad happens.
Old May 11, 2004
Spider883's Avatar
9K Redline Owns U
^^ good luck and take some pictures
Old May 11, 2004
djmota's Avatar
Originally posted by PacSmalls
what is de-burring?
when you are grinding away at the gasket, the oppisite side will get a little ridge of metal built up you need to grind the ridges down so the gasket can still seal.
Old May 11, 2004
Update: I got two of the ports matched on the gasket and it took forever. I needa new dremel attachment. But I did it with both halves together, and now the metal is all bent. I guess it will flatten with everything put back on the car.
Anyway, good news is I don't have to port my HP replica header! Ports are the same as the new ones I made on the gasket. I can't believe how small the stock ports were.
Old May 12, 2004
http://www.7thgencivic.com/forums/sh...hreadid=154478
yyyktk1
Sep 12, 2015 04:02 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
fvckbg
Sep 8, 2015 09:55 PM
tooly145
Sep 5, 2015 01:05 AM
dantheman42
Sep 4, 2015 01:10 PM
