electrical switches
Old Apr 30, 2004
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
electrical switches
Warning, sorry for my crappy spelling...
Ok... I saw a sweet civic that has switches on the center consol in the little dip under the e-brake. Right now I have an indiglo honda H and a LED exhaust tip. They are both wired to my license plate so they only turn on when I have at least my parking lights on. Problem is, I don't know how strict the po-po's are gonna be in my area, and I don't want to end up with another ticket for a stupid reason. Does anyone know how to install switches in the compartment and run the pre-existing wiring to be able to control them with the switches. Both have teir own fuses, so I don't know if there is a length issues with that either...
Sum 1 please help...
Oh yeah... BTW this is kind of what I am looking to do... I need at least 2 because I could more than likely wire the emblem and the tip to the same switch, but I am also looking at installing underglow once I get my body kit installed...
Thanx,
Jaymz
Old Apr 30, 2004
Basically you make a circuit.
Power wire from battery positive to switch. Then another wire from the switch to the power wire of the indiglo emblem. Then you just connect the ground of the emblem to the car body (metal). And the switch will have two terminals to connect wires coming from the battery and to the emblem. Then when you flip the switch, it connects the two and supplies power.
Old Apr 30, 2004
So it's power into switch, line out to emblem/tip and then use the my original method for grounding right? But what about the fuses that the tip and emblem currently have, are they like an amp and need to be so many inches from the source of power or am I free to have an excess amount of line between the switch and the fuse?
Old Apr 30, 2004
Technically the fuse should be as close to the power source as possible. So you could put one on the power line near the car battery to protect your switch. If the emblems and tip already have fuses, it should be fine. Fuses are just to protect your equipment in case of a power surge. I wouldn't worry too much. The fuses they come with should be sufficient.
Old Apr 30, 2004
Blueboi105's Avatar
Blueboi105 is an unknown quantity at this point
those are nice switches.. but arent those the NX kit switches for purge, bottle warmer and arming?
Old Apr 30, 2004
skipbarber's Avatar
^ thats what i was thinking
Old Apr 30, 2004
I think so, but I still like the idea of using these for my electrical seeing as how I don't have N/X in my car. I was just saying that this is something that I would like to concider modeling the switches that I want to install after.
Old May 2, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
You should take the LED exhaust tip off buddie..
Old May 2, 2004
thomusvoo's Avatar
Newbie Member
thomusvoo is on a distinguished road
can i have more pic of your CF console kit????
mjdiaz89
Jun 21, 2016 09:26 PM
Jul 12, 2015 11:54 AM
jody501
Jul 10, 2015 11:01 AM
ZILLA
Jul 10, 2015 06:05 AM
jferristx
Jul 8, 2015 10:09 PM
