Yes I have searched it...
Old May 4, 2004
HondaChevy's Avatar
HondaChevy is an unknown quantity at this point
Question Yes I have searched it...
and done all of things read in what I found but still need help. And before I start with the rest of this yes I have an AEM CAI installed on my car.
P0113 Intake air temperature circuit high input...can someone please explain this (if my understanding is incorrect) and how to fix it.
My understanding of this is that the signal being read is higher than the maximum threshold allowed by the sensor. So in theory if you add some resistors than it would cure the problem. I used the 4.7k 1/2 watt resistor as noted in the installuniverstiy.com trick but that did not work. I tried resesting the computer (pulled the FI ECU fuse plug {15} and unhooked the batt) only to have the light instantaneously come back on. So if the resistor is the answer does anyone know what ohm resistor to use. Any constructive answers will be greatly appreciated.
Thanks for your time and your knowledge,
-HC
Old May 5, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
OK YEA SURE
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
winanthony94
Sep 25, 2015 09:05 AM
chiquita.banana
Sep 24, 2015 09:42 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
