re: i need some help
Old May 10, 2004
Senthus's Avatar
Senthus is an unknown quantity at this point
Hi everyone, i just got a 2004 civic se for a present. .and installed one 12" sub in it.. kept the factory HU and got a passive line reducer for the two back speakers to rcas, however, everytime the amp is on, the sub makes wierd thumping noises. can anyone help?
Senthus
Old May 10, 2004
Senthus's Avatar
has anyone had this problem, or had any problem taking the signals from the rear speakers?
Old May 10, 2004
Mr.Modify's Avatar
are they just thumping like thump/thump/thump/ or do they thump when you turn it off or on? is it like a pulse sounding sound like the sound of a pulse?
Old May 10, 2004
Da1lyDr1ver's Avatar
you might be right about the signal for the speakers. or your RCA cables are too close to you power wires causing "noise" in the sub. check your ground also.
Mr. Modify, what does it mean if it thumps when you turn it off??? i have that problem.
Old May 10, 2004
Senthus's Avatar
not when u turn it on and off... but when its actually on and then the speaker flexes like crazy with a thumping noise.
Old May 10, 2004
hi2nr's Avatar
hi2nr is an unknown quantity at this point
My friend had the same problem too. His had a problem with the signal cables so u might want to check those out. Other than that you might have some cheap stuff on your ride.
Old May 10, 2004
streetglower's Avatar
subs are supposed to thump, that is why you buy them.
Old May 10, 2004
INCivic's Avatar
INCivic is an unknown quantity at this point
Old May 11, 2004
Quijano187's Avatar
The Evil Genius
Quijano187 is on a distinguished road
its the ground ... either tighten it up or sand it down more... put im tell u if your hear it when it turns on and offf.. 8 10 times its the ground.
SQCivic
Aug 29, 2002 02:34 PM
Pyro
Apr 30, 2002 06:35 PM
Pyro
Bolt-on Engine Performance
Apr 26, 2002 10:55 PM
htowncivicEX
Jan 21, 2002 11:48 AM
