Stretching sound from rear drum brake?
Old Apr 12, 2004
zen_master's Avatar
Just like the topic..
have you guys ever experience this? what might be the cause?
there are two situations:
1. when I pull the hand-brake (emergency brake)
2. when I push the brake pedal in IDLE condition
what's wrong?
i noticed the "caliper" of the rear drum brake also rusted...is it normal?
thanx!
Old Apr 12, 2004
Quijano187's Avatar
The Evil Genius
Quijano187 is on a distinguished road
its it hard to pull e-brake or do it seem way too easy.. need more info
Old Apr 12, 2004
zen_master's Avatar
thanx for the reply.
when i pull the e-brake, it's quite normal...i think..
but, on the end.....when u have to pull the e-brake bit-harder, there is a stretching sound... from the rear brake...
same thing happened when i pressed the pedal...
no sounds from the front brake...thanx god.
nothing wrong when braking on the road..
problem comes when the car's idle.
have u also experience bit "wingy" noise when you turn the steering wheel a 'lil turn in IDLE condition?
Old Apr 12, 2004
Quijano187's Avatar
The Evil Genius
i kind of have that problem too, but i only notice it when i first start the car and its cold. second does the ebrake feel realy tight or loose .. if it feel noraml.. then i should be fine .. if too loose like mine.. when i feel i have pull all the way up.. then u might need to adjust your shoes in the back.. you might need new shoes in the back. or it can be the brake lines.. more info please
Old Apr 12, 2004
dirk21's Avatar
dirk21 is an unknown quantity at this point
brakes usually rust when it sits there for a period of time. or if it's really moist. that's always normal. cause when you drive and hit the brakes a couple of times then the rust should go away. this kind of weather usually causes the noise too but after you drive it for a while the noise should go away.
Old Apr 13, 2004
zen_master's Avatar
hm hm hm
yup, thanx for the infos again guys..
i think im gonna tighen up the e-brake while doin the REVO SS DIY...
i just noticed that the "stretching" sound was actually when I pull the e-brake and then pushed the pedal....that's probably why...i put too much foce on it...
i think im gonna tighen up the cable, later...
thanx guys!
anyway, i looked and the "caliper" of my drum brake...however, it's really rusted....
hm....it's not the inside...but the outside...you can look at it directly when ur lookin at ur rear wheel....
Old Apr 13, 2004
Quijano187's Avatar
The Evil Genius
just paint it
Old Apr 13, 2004
zen_master's Avatar
nah, im with stock wheelie...no one wanna look at it...
actually it's not only rust....but....it's bit cracked caused by the rust..just a bit though
u know what i mean?
Old Jun 18, 2004
Aohan815's Avatar
Aohan815 is an unknown quantity at this point
dude its from the dust....clean ur drums with brake cleaner and sand em down with fine sand paper.....use an air gun and air blow the dust off ur brakes....dude did it make a difference with my car!!
sbi
20
Oct 23, 2015 01:34 PM
rtachs
Jul 16, 2015 05:32 PM
Optimus34
May 25, 2015 11:52 PM
rhvic
May 22, 2015 03:06 PM
Broadbeb
May 14, 2015 09:49 PM
