2001 Civic alternator belt adjustment
Old May 4, 2004
vpelegrino's Avatar
vpelegrino is an unknown quantity at this point
It seems to be very easy.... I have already found the wing nut bolt that should be used do adjust the alternator belt. Now, my question is... Do I have to loose the alternator first, just like has to be done with the PS belt?
Thanks!
Old May 5, 2004
andyman97's Avatar
Turbo Guru
The tensioner should force it out. It wouldn't make sense to loosen it before. What is happening is; you want to make the belt tighter. If you loosen the part before tightening it, it will bring it in closer and make it even looser. What you may want to do is loosen the tensioner as much as needed, then loosen the part, push it out as much as possible, retighten it then tighten the tensioner up. That is what you should do.
mattdoc
Mar 14, 2017 12:10 PM
bambuski
Nov 12, 2001 10:35 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
