IAT Sensor
Old May 1, 2004
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
IAT Sensor
I was going through ebay and I found a guy selling resistors that you install between your IAT sensor and its supposed to boost your car 7-15 horsepower. Does this sh*t work or is it all a load of crap??? Has anyone tried doing this b4? And just for my own knowledge cuz I am stupid like that, where exactly is the IAT located? SOooooooo many questions......
Thnx 4 da help,
Jaymz....
Old May 1, 2004
dragoon's Avatar
load of crap
Old May 1, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
I got a rock here and when u put it in ur car it gives u 20whp for sure
Old May 1, 2004
Ok... yeah thanx 4 nothing @$$ holes.... Instead of actually helping sum1 out you instead decide to be jerks...
hahaha... you guys are freakin hilarious.... Can sum1 with actual info who does not feel the need to be a smart *** help me out please.... I am asking for serious help not jokes...
Old May 1, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
1st ur a dumb *** if you think that works..
2nd dont call me a ******* ur a New Member and u think **** like that is gunna work
3rd THE ****IN SEARCH BUTTON IS ON TOP USE IT
ooo yea welcome to the site
Old May 1, 2004
Hey bro... thnx for the help... I ask questions before I buy to get peeps opinions... Didn't realize that I was gona get so much sh*t as a result... so to prevent any more crap can a mod please close this for me....
Old May 1, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Not to be a *** but just use the red button man
Old May 1, 2004
tfnaaf's Avatar
BLDNPSI Mod
actually to the dumbasses above, it CAN increase HP if done properly. The best way to do it is to measure the resistance of your IAT when its COLD. Find a resistor that matches that value. Dont just buy a resistor off e-bay cause someone says it will work for you. Will you gain substanial HP ? Prolly not. But it can be a noticable/measurable amount of increase
Old May 2, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
ok well u try it dyno it out and if ur right Ill give you a 100bucks I know its not gunna work I talk to peeps about it all the time ITS NOT GOING TO WORK Just end it now
Old May 2, 2004
Mirage's Avatar
Mirage is an unknown quantity at this point
The auction is for a resistor that you wire up to your IAT (Inlet Air Temp) sensor. By putting a resistor across it's connections, you make the sensor output read artificially cold. By doing this, the ECU adds extra fuel thinking it's running on a cold intake air charge, or put otherwise, making the ECU think the air is more dense, therefore needing more fuel to run properly.
The extra fuel *might* add a little bit of horsepower but it *will* reduce fuel economy and can make the engine run a little rough under certain situations.
There is also the potential that the ECU might pick up that the sensor is acting "funny" and throw a code. If there was a little work done in selecting the resistor, this could probably be avoided in all but the coldest ambient conditions but this guy is selling a $0.10 resistor from Radio Shack for like $20 so I'm not going to bet that he is honest in the first place nor that he ever had it on a 7th gen.
IMHO, don't bother with the magic fixes, they almost always prove to be a scam.
Old May 2, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
I have the following mod to bypass the AIT sensor. I am running boost and the SF kit insall instructions say to leave it loose in the hot engine bay. Check out the following link if you plan on a DIY.
http://www.installuniversity.com/ins...ricker_mod.htm
Old May 3, 2004
dragoon's Avatar
Re: IAT Sensor
your question: is it a load of crap?
my answer: yes.
i was in no way "being a jerk". stop whining.
Old May 3, 2004
zen_master's Avatar
hahahahhaa. omg guys.
i think he realized in the first place that the thing he's talking about is full of crap.
anywho, i wonder how he feels being treated like that. i think, a thread which explains about how that resistor actually work (as a piece of crap) as another guy explain above is much more better for a lot of people who read it. especially noobs...
i think, it's a better way to express the "crap"-tastic of that piece of crap compared than those useless flames that you guys did...
seriously, i do think that the op must use the search button.... yes, it's correct....but being treated like a jackass, i don't think that's correct...
ps: anywho, by reading that educating thread about this resistor, i gain another knowledge today....
Old May 3, 2004
zen_master's Avatar
THIS IS GOOD. And yes, it's done by a new member..... welcome! =)
Old May 3, 2004
guns's Avatar
Skyline R33
He leftout it might advance your timing a slight bit to make better use of the added fuel.
Old May 4, 2004
Mirage's Avatar
Yes, I left that out. I also left out that it might retard you timing. It depends on how "cold" the intake air is. If the ECU thinks the engine is running cold, it may retard your timing to keep the cat hot and running in it's optimal range, to help reduce emissions.
Old May 5, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
good job guys
Old May 14, 2004
82801BA's Avatar
82801BA is an unknown quantity at this point
I have a question that arise from it....For a 3.3k-ohm and 4.7k-ohm resistor, what will be the difference?
I know that Civic engine is running LEAN at ALL RPM stock, even you see the dyno graph showing 12.5 doesn't mean it's rich. And putting in a resistor in place of IAT sensor will rich out the fuel and therefore giving out more power. Sounds strange, but this is how the D17A, especially D17A2 and A6 is designed for.
Old May 14, 2004
82801BA's Avatar
My dyno result: more fuel causes more power in D17A2, and less fuel gives more power in all other engines.
Old Apr 25, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
so what resistance level do you recommend, i've heard 3.3K @ 1/2 watt tolerance
Old Apr 25, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
exactly thank you
BootyDo
Jun 21, 2016 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
Dani1993
Jul 24, 2015 09:02 AM
mistermenphis22
Jul 13, 2015 04:43 PM
