- venom doesn't work? hah your wrong!!!!!!!!
- <phx>i need to post this again
- PLEASE HELP ME!!!!!!!=(
- DIY for underbody neons
- help please =)
- Another question on the stock cd player
- HID in TYC projectors
- Good light bulbs to use with the TYC projectors...
- Need Help, Police,EMS,EMT,firefighter or anyone who might know
- torque on wheel lugs nuts
- Internal engine mods vs engine life
- need help with rsx sway bar
- Wilwood brake install on 01 civic in SCC
- ...removin back seat
- Different Question w/ Factory CD Player
- Maint. Required Light
- NEED HELP WITH STOCK CD PLAYER
- mait. required light?
- !!! Injen Intake... did they forget a part? Now what?
- APC super whites
- painting cf hood
- turbo
- bad struts?
- How much does gasoline weigh?
- Parking lights HELP!
- my lil theory.. prove me right..
- AT to MT
- jet chip / venom 400
- Civic sits uneven
- CAI = Better Gas Milage
- Follow up to warped bumper thread...
- Tips on installing OEM Spoiler
- fog light install?
- brake lights dont work
- Governors?.....
- O2 sensor on header?
- Will "Liquid Nails" adhesive work to seal cleared headlights?!
- TYC Projectors, and wiring harness. NO PW!!
- attn: people with aem cai for LX
- can anyone tell me how to install ...
- plasma booster
- I need LOTS of HELP!
- how to clear water spots in a leaking altezza?
- k20 swap asap
- 194 bulb LED problem
- REQUEST: Pic(s) of bypass valve on InJen CAI
- Anyone know where the temp sensor is?
- Headlight Wont Turn Off
- injen cai rd...automatic
- DX To EX Cluster
- Help with front turn signals
- I searE Brake ????
- heated seat and mirrors...
- headlight isnt working
- Neuspeed Sports or Eibach Sportlines?
- maint required light
- Have a 1996 to 2000 civic manual??
- Any body with real HID projectors in stock housing or TYC Projectors (Exbauer......any body)
- Need help on installing S-2000 Push Start????
- flip flop trunk
- RSX-S rear section exhaust on a 7th gen?
- Shifter has some play in it...
- failure
- EX exhaust on LX ??? would it work?
- anyone near Tampa?
- Xtreme Imports
- Shift knob doesn't screw on!!! HELP
- Need info on turbos, psi, and such
- ecu
- Shift Boot Question.....
- HELP... Can't wire damn fog lights
- Roof scoop on 2k1
- WET OR DRY, I Searched!!!
- More S-AFC Settings help
- parking light off
- HONDATA!?!?!?
- k24 2.4L in civic
- Maintnance Required light
- Could this be used as a turbo manifold?
- Dash Board help!!!!!! Fast
- SRS light
- engine dress up
- Stock SI CD player in EX?
- another question
- QUICK IN NEED ADVICE
- Can you do this??
- Chrome trim question.
- bad noises...
- MTEC high intensity bulbs
- Got my aftermarket shift knob...how do I install? It has wires for indiglo light!
- RSX-S Anti-Sway hitting
- how do i install a Valet 551T on my Viper 600? alarm techs look
- ?? how do i get the unlock part off of the glove box?
- Went to the track yesterday with my EX
- Does anyone know the real answer?
- Powder coating?
- Resetting Maint' Required Light
- Headlight/remote entry question.
- Shaved emblems
- DIY Bezel Paint
- air ducts
- Which Engine will Fit in my 2001 civic?
- Anyone else have a warped rear bumper?
- HELP! Air/Fuel gauge install....
- Recharging A/C
- shaving
- HELP PLZ MY GAUGES ARE MESSED UP
- Question about Headlight Flasher
- idle RPM???
- Another DIY version of spare under car w/large pics...
- i know people have asked about this but...
- HP/DC sports header/cat question *HELP*
- DIY Idea: Turn Signal Mirrors
- WTB: Spring Compressor
- how to remove glovebox?
- Can't find a K&N Air filter, any substitutes?
- Removing Paint on DIY trim pieces.....
- Differences between D17 and D16??
- Shaved Door Handles
- our civics are 4 door isolated???
- indiglo gauges, needle doesnt work!!! need help
- Help! Changing bulbs on m3 mirror!
- boost controller question
- AEM TruPower pullies???
- Indiglow Wiring??
- Need help with trim paint…
- Got a problem about changing around parts
- Yea i've searched... Injen CAI pipe size?
- AEM bypass install
- scratches
- Painted Headlights
- repairing dent in front bumper
- Hit Different Limiter
- Can I cut this off my car, I don't think I need it, (pic included)
- question on gels for dash,
- Anyone w S-AFC tested on dyno and ...
- Trunk removal and spoiler LED question
- Where's the computer in the 7th Gen?
- how sensitive is yours
- Fluorescent tube
- WHen does VTEC kick in
- springs makin noise
- exhaust
- Engine Bog Down between 3 & 4k rpms
- Wiring Fog Lamps into Parking Lights..
- finally got it done!!!!
- whriling sound from timing belt
- Do I need to reset my ECU?
- HELP! my car is running like garbage
- Installed Mobile 1, gas mileage is getting worse
- gsr seats
- mural
- wiring an LED??
- DAYTIME RUNNING LAMPS
- Crimestopper alarm system for 2001 civic lx (2dr) Please help!!!
- Nitrous under back seat....
- help!!
- anyone install tsunami front bumper?
- Intake Blower?????????
- o2 sim problems?
- injen intake
- Custom Grille...
- DIY trim is a little rough?
- Different intake for different models??
- stupid intake question
- Positive V-AFC will not work!!???
- Need help fast w/ problem!!! Installing Koni's & can't get the control arm part of the strut ho
- Question on custom axal back......
- E BRAKE HANDLE
- How do you remove the Silver auto shifter trim?
- Injen CAI and Fuel Line Problems....
- cai to sri please help!!!!!
- REMOVING PULLEYS ?
- Driving without a air filter.
- CAAR WONT START!!
- What to use to Paint Brake Calipers? (edited)
- turn signals
- Projectors
- Did I do this right? NEED HELP!
- V-AFC and n02
- Enclosures 2 12" type Rs
- Differences between white lights??
- beam pattern adjustment
- Koni Help ASAP
- is it bad for the car to cut out the plastic thing in the lower grill
- <phx> a/c problem
- How to install Eyebrows?
- what do i do!!!!!!!!!!!
- how to fit 4 12"subs
- Vibrating steering wheel at 70 mph
- Need some help with wiring!!!
- Install Door Speakers
- People in NYC
- DIY CAI??
- anyone cut a coil off a 2.0 drop??
- Lowering my car. HELLLPPP!!
- Difference Between US Model EX versus CDN Model LX?
- Intake resonator...
- Considering a Swap
- trans fluid
- for anyone with a harsh shifting automatic....
- Yes another Nitrous questoin
- problem......car hesitates
- diy mild port & polish?
- what are little things that i can do to make my car look better without spending money
- Looking for good hyperwhites
- i have the chrome projectors and it seems as though my beam pattern is off
- Got Noise!?
- My mechanic's reply to some of my suspension noises
- Brake lights dont work!!!!Need reply asap
- D17: Bore & Stroke = ?
- Does anyone know where the thermostat temp. sensor is located?
- got cd stuck behind 3rd brake light..
- AEM Cold Air Intake Instructions
- Anyone else see this?
- DIY: E-Brake Adjustment
- CAI Driving Question
- is it okay for springs to be upside down?!
- Installed Injen CAI... Can't get battery back in... HELP!!!!!!!!!
- Flywheel nuts : Please read.
- Dash Kit Painting
- Would 5th gen moroso oil pan fit?
- Nuespeed springs makes my brakes click?!
- Installing 2 sets of neons?
- Removing E brake handle
- how many neons can be hooked to a 30 fuse?
- B-Series swap + other problems
- Help with turbo sizing...
- My DG Motorsport Carbon Fiber Hood FLEW OFF MY CAR ON THE HIGHWAY!!!
- Header Installation
- Aftermarket Shift Knob...
- Taking off the shift knob?
- Relocating Battery to trunk
- Door Trim
- exhaust question....
- Header Help!!!
- clanking noise
- Updated Again: Custom Pedal Design
- Pulleys, alternator, power?
- suspension making weird noise! HELP!
- Koni Help, now !!!
- Ebay Projectors...
- aem cai question, yes i searched
- Installing neons in car! NEED HELP!
- Question about head light parts...
- smoke in air vents!!!
- What is the best way to cut interior trim peices?
- Good Solution to Attach Grill Mesh...?
- has anyone towed using a civic?
- Help! New noises (searched and not found)
