Header Installation
Old Aug 3, 2002
scatman's Avatar
Still in the game...
Header Installation
I wanna know if its possible to install a DC Sports header myself,if so could you tell me how and the tools that ill need, also if the header fits to the stock catalytic converter...please help
Old Aug 3, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i am sure you can do it yourself, but i wouldnt recommend it. you would need a jackstand and some wrenches. thats about it i would say.
Old Aug 3, 2002
C2i0v0i1C's Avatar
SuperMODrizd
get some jack stands, ull need a 12 and 14 millimeter wrenchs or sockets, un bolt the bolts that are going into the block, and unscrew where the downpipe connects to the manifold, DC applies to the EX........LX takes some fabrication. put the DC in place make sure to use the stock gasket, thin little metal thing, and then put all the same bolts back in the same places
Old Aug 3, 2002
liquidblue's Avatar
liquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trusted
hey C2i0v0i1c, did you do this yourself? if so, how long did it take you, doesn't sound like more than an hour from start to finish. if it's that easy i'll go do that myself rather than pay good money for it.
Old Aug 4, 2002
lilbluecivic's Avatar
lilbluecivic is an unknown quantity at this point
its definately easy, maybee 45min, the two bottom bolts were the hardest
Old Aug 4, 2002
Pedrito's Avatar
Pedrito is an unknown quantity at this point
you need a 12 or 14 mm (not sure which one i forgot) and 17mm for the bottom 2 bolts that connect the catalyic converter pipe to the header piece it is very easy just dont drive your car before you put it on!
Old Aug 28, 2002
Orez's Avatar
Orez is an unknown quantity at this point
Are the DC headers the best for the EX[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Orez
Old Aug 28, 2002
zetaR's Avatar
zetaR is an unknown quantity at this point
Quote
[hr]Originally posted by: Orez
[hr]
Is the DC TCS exhaust the best?
Is the AEM CAI better than the Injen CAI?
Does the Kaminari Kit look better than the Wings West G5 kit?
Basically, it's going to come down to preference. One person may sware by their exhaust and despise another, and vice versa. I believe most people who have an EX with an aftermarker header went with the DC sports because it was the best fit. However, the ones with the HP header with high flow cat that took the time to get it installed have been saying good things. There's also some other options like Arospeed and some others. Check out the parts section. Most will probably say DC or HP.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
