Koni Help, now !!!
Old Aug 2, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
Koni Help, now !!!
** i did search **
I installed the koni yellows w/ my friends last week. everything went well, excpet right now, when i drive my car slowly, there is "Cluck" sound kept coming off the front of the car. it doesnt happen while i'm driving fast, it just happen when i drvie slowly, braking, and turning my sterring wheel. do u think its the controll arm bolt problem, that i didnt tighten them well?
Thanks...
Old Aug 2, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Normal. It's setting in. I had the clunk noise for about 2 weeks with my springs.
Old Aug 2, 2002
CivicVTec's Avatar
thanks.....i feel better now
Old Aug 2, 2002
JumpingBean's Avatar
JumpingBean is an unknown quantity at this point
How hard was it to install them? Im goign to install mine with my skunk2 coilovers next week.
Old Aug 2, 2002
CivicVTec's Avatar
it was pretty easy to install them but putting them back together was the hard part. Make sure u have something to support the spring tension when u tried to put the "Thing" back onto the car. for the front, go to autozone and get a "control arm bolt puller", it's like $10, that will make your life lots easier to install the front sturt.
Old Aug 2, 2002
One of my best friends works at an autobody shop so i will have too the tools i need.
Old Aug 2, 2002
CivicVTec's Avatar
sounds good
Old Aug 2, 2002
happynappy82's Avatar
happynappy82 is an unknown quantity at this point
My koni's are causin problems. i think that they werent properly tightened ( the koni strut inside the factory-strut housing) , and that is why two seperate shops could not allign my front wheels. THey both have an inch of give in either direction, so when im climbing into my steep a$$ driveway i hear both my front wheels "click" as they shift to go up the curb.
Old Aug 2, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
Mine clicked for a week or so, then I retightened everything and it went away, although the front still doesn't feel quite as solid as the stock setup was, then again I have the konis set fairly stiff. No worries man, nothing catastrophic will happen as long as the cotter pin is still in on the steering arm.
Old Aug 2, 2002
CivicVTec's Avatar
yeah..i think i'm going to tighten every bolts i took out when i was installing the Konis...thanks all
Old Aug 2, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
when do the full front replacements come out?
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
cukaracha
Aug 29, 2015 05:27 PM
cukaracha
Jun 7, 2015 03:32 PM
Rogelio Rey
May 24, 2015 08:30 PM
