DAYTIME RUNNING LAMPS
does anyone know how to disable the daytime running lamps? sometimes i just want those damn lights off!!
i also did a search but found nothing on this site... i'd appreciate any info
What? My 2k2 civic lx doesn't have daytime running lights. They've proven that daytime running lights reduce accidents.... they're not that bad.
You could just disconnect the DRL light bulbs. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
in Canada they're required by law...
All they do is have the high-beams on at a lower power.
They're annoying at times... if you're ever at a drive in the facotry method to turn them off is:
- Turn off car
- Set parking break
- turn on car
the lights will stay off till you drop the break.
I'm sure it would be easy to wire a switch with a little investigation.
- Turn off car
- Set parking break
- turn on car
try removing the fuse. read the manual. it should tell which fuse is for the daytime lights. hope this works. unlike u guys, i want my civic to have day time lights. i dont know y i want to.
Canadian models come with DRL, its a law here in Canada... anyways i removed mine and many of my friends Day time lights, u cant remove the bulb because its the same bulb as your low and high beam...so ne ways just pull out the fuse that says day time running light, or DRL on it and done, there are 2 fuses, one is for the light itself and one is for the little DRL sign in ur dash to turn off,
good luck
good luck
stryder12
Jun 30, 2015 08:33 PM
eorlando1
May 17, 2015 11:16 AM
