k24 2.4L in civic
Old Aug 18, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
k20 2.4L in civic
The honda crv and the civic are built on the same chasis. I am wondering why we cant swap in the 2.4 liter k20 into our civics? There is enough room obviously because the engine bays on the crv and civic are almost the same as well as the rsx.. What seems to be the swapping problems? Is it do to the fact that the engines are all backwards compared to ours? I mean yeah the header is on the back and the throttle bodie is on the side but thats no reason why it shouldent fit? Couldent crv mounts even be used in the process? Somone fill me in a lil on this one...
Old Aug 18, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
yep.. htowncivic talks about that here IB said it would be easier to swap the CRV engine into the civic.
Old Aug 18, 2002
R3DF0G's Avatar
R3DF0G is an unknown quantity at this point
First off, It's K24[IMG]i/expressions/face-icon-small-wink.gif[/IMG] Anyway, I would think there might be some clearance issues with the hood, plus you would need a tranny from an RSX or something since the CRV is either RWD or AWD. Other than that, It shouldn't be too hard.[IMG]i/expressions/laugh2.gif[/IMG]
Old Aug 18, 2002
Umm no i would change that over to so i would have an awd civic. And yes its possible and has been done countless times.
Old Aug 18, 2002
Edens's Avatar
Edens is an unknown quantity at this point
Not to step on anyones feet, but the CR-V comes either FWD or AWD not RWD and the new 2002 and up CR-V is avalible in a 5-speed too.
Old Aug 18, 2002
civichx81's Avatar
civichx81 is an unknown quantity at this point
so if anybody has the money, they can use the k24 bottom end and use the k20 vtec head and transmission. right?
Old Aug 19, 2002
briang's Avatar
briang is an unknown quantity at this point
The problem with the K24 is the stroke. It is gawdawful long and would be difficult to hotrod. It would not stand up to the revs that the K20A head is tuned for. It will bolt up though. The thing to do though is use the K20A crank so that theengine can rev.
brian g
Old Aug 19, 2002
FlexEX's Avatar
FlexEX is an unknown quantity at this point
I read something in Hondatuning about swapping a K24 with a S2000 head. supposedly then you could have all the torque but with a higher redline.
Old Aug 19, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
According to the August/September issue of Honda Tuning, it is an easier task to swap the K20A2 from the RSX into the Civic by using the subframe from the RSX, as it simply bolts up to the Civic.
Old Aug 19, 2002
dragoon's Avatar
k24 block with f20 head? are you sure?
a whole cr-v awd drivetrain would be nice [IMG]i/expressions/laugh2.gif[/IMG]
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
Lightman
Nov 10, 2001 06:44 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
