Need some help with wiring!!!
Old Aug 8, 2002
BLiTz's Avatar
BLiTz is an unknown quantity at this point
I bought a shift **** that lights up the numbers in a blue color but my problem is I don't know which of the wires next to the shifter is a positive wire that is connected so it'll light up when I have my parking lights on. Anyone have any suggestions or might know please help. Also what would you recommend to use as a ground?
thanks!
Old Aug 8, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
i dont understand a shiftknob that lights up numbers huh o wait u have a auto right i want to see the shifter link the product
Old Aug 8, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
It didnt' come with instructions?
If you want to wire them to your parking lights you can remove your center console and look at the above link for DIY and find the wireing diagram there. Then tap into the wire for your parking lights and run it under the center console to your shiftnob.
MY SUGGESTION: Your lighter plug is only powered when the car is turned to ACC or is on so, if you tap into the lighter + wire you will be able to do it with much less trouble.
Old Aug 8, 2002
VNlilMAN's Avatar
The Standard One
if you have an auto its easy, just hook it up to the PRNDD32 thing
Old Aug 8, 2002
smpcivic's Avatar
smpcivic is an unknown quantity at this point
post some pics of that shifter if you can...it sounds cool
Old Aug 8, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
Pics here
Old Aug 8, 2002
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
get a one of those testers that light up, touch it to the wire, if it lights up, then its the positive wire. or, get a volt meter, and touch the neg. side to a ground and the other to the wire, if you get a reading, then its positive, if no reading, then its negative. or do our cars have rated voltage?
Old Aug 8, 2002
sadboy916's Avatar
o thats tiiiiiight not rice at all unless there are wires hanging around
Old Aug 9, 2002
BLiTz's Avatar
It's for a manual and mine is a gunmetal color. It matches my deck with the blue lights and use to match my gauges. I had the apc reverse indiglo gauges but it looks like it's time to cut them out!!! Any other help would be great and thanks for the help already!!
Old Aug 10, 2002
BLiTz's Avatar
THANKFULLY I didn't have to cut and KILL my APC reverse indiglo gauges.. The negative wire somehow was cut so there was NO GROUND. I just did it ghetto fabulous style and stripped the wire and wrapped it around my screw. I'll check out the diagram and maybe it'll be easier to buy a tester but aren't those hella expensive? Any other help would be appreciated and as soon as I get it done look for pics b/c I think it'll be a sweet looking interior with the gauges, deck, and shifter being a blue light...haha
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
