HELP! my car is running like garbage
Old Aug 12, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
hey guys, i come to you looking for some help! honda techs please read!
when first starting off in first gear i generally bring the car to about 3k rpm and then shift......off the line the car runs fine w/ no problems, but once i shift into second is where the problem occurs....
when i shift and the rpms drop and i get back on the throttle, the car doggs horribly, burrbles, and even occasionally BACKFIRES! (sometime out the ehxuast, sometimes out the intake!)......it will repeat this as i shift into third and fourth gears as long as i shift at 3k rpm.....
i can not recall the car ever running this poorly....
if it help, i have an AEM CAI and DC SPORTS exhaust....
please, all information, comments, and help are truely appriciated!
mark
Old Aug 12, 2002
PoopyRay's Avatar
PoopyRay is an unknown quantity at this point
there isnt anything clogging your air flow is there? i.e. a banana in your tail pipe?
Old Aug 12, 2002
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Check both o2 sensors, the sensor going into the AEM CAI, fuel connections to the injectors and on the rail, just make sure connections on everything are tight. Are you getting any check engine lights?
Old Aug 12, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Yeah, most def check your connections. It sounds like O2 sensor to me but I've never really dealt much with Honda engines. I'm a rotor head!
Old Aug 12, 2002
mattymatt's Avatar
mattymatt is an unknown quantity at this point
You have a warenty, bring it to honda and let them worry about it.
Old Aug 12, 2002
theguysmiley's Avatar
theguysmiley is an unknown quantity at this point
Quote
[hr]Originally posted by: mattymatt
You have a warenty, bring it to honda and let them worry about it.[hr]
I believe exhaust and an intake voids your warrenty. Am I wrong?
Old Aug 12, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
you are wrong in that they have to prove that the bolt on caused the problem in order to void the warranty. if it didn't cause the problem, then you're still okay.
Old Aug 12, 2002
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
Quote
[hr]Originally posted by: AFlyer
you are wrong in that they have to prove that the bolt on caused the problem in order to void the warranty. if it didn't cause the problem, then you're still okay.[hr]
yeah but you know dealers.... they will immediately pop your hood and see that you have an intake and tell you right there that that is the problem, and try and give you a big run-around.
*PS - AFlyer don't take that the wrong way, I'm not trying to flame or anything*
Old Aug 12, 2002
First to spool
Intake and exhaust may NEVER violate engine warranty. Ever. For any reason, except hydrolock. Anything before the throttle body or after the exhaust manifold connection has no effect on the engine warranty as long as the added part does not cause 2.1 or more PSI to go through the throttle body. Taken directly from Honda's full contract text.
If a dealer tries to tell you that a SRI, CAI, headers, or exhaust caused your engine problem (and the part was correctly installed, CARB compliant, and there was no hydrolock), then call Honda's Corporate Warranty Administration, get a full copy of the text, and go beat the service tech over the head with it until he fixes the engine.
Old Aug 12, 2002
Hefe's Avatar
Quote
[hr]Originally posted by: RiceBurnrEX
If a dealer tries to tell you that a SRI, CAI, headers, or exhaust caused your engine problem (and the part was correctly installed, CARB compliant, and there was no hydrolock), then call Honda's Corporate Warranty Administration, get a full copy of the text, and go beat the service tech over the head with it until he fixes the engine.[hr]
WOW.... well said
Old Aug 12, 2002
RookieTuner's Avatar
RookieTuner is an unknown quantity at this point
i called the honda warranty service and they told me that the only way for an aftermarket part to void warranty was if the problem was directly related to it. i want to install headers and a high flow cat, will they void my warranty should something happen to my engine? will an aftermarket header and cat. pose any problems to my engine?
Old Aug 12, 2002
First to spool
Mechanically no, but it could violate warranty unless the header and cat both have CARB exempt status, and still use both stock o2 sensors.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
usajags84
15
Aug 19, 2015 03:12 AM
dragonsblood
Apr 27, 2015 12:28 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
