AEM bypass install
Old Aug 13, 2002
LuvDatCivic's Avatar
LuvDatCivic is an unknown quantity at this point
AEM bypass install
I installed my AEM CAI last week and I want to install a bypass now. I searched the forum and their seem to be conflicting opinions on where to place the bypass and if it is necessary to cut the tube. Will the bypass still be effective if I place it inbetween the two pipes? Thanks!!
Old Aug 13, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
what does the bypass valve actually do?? i have an injen cai so i would like to know what it does.
Old Aug 13, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
what a bypass valve does: if the air filter is submerged in water, the engine trying to suck air in will create a vacuum in the intake, and suck the water up, just like a straw. the bypass valve releases the pressure and prevents the water from entering the intake. if water does get in the engine, it causes something bad called hydralock. it usually ends up destroying the engine. the bypass valve is cheap insurance against it. if you have a CAI i would get it no matter where you live. where you put it doesnt matter, but generally toward the throttle body is usually where it goes.
and it will still be effective if you put it in between the two pipes.
Old Aug 13, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
Screw the bypass, I have the AEM CAI and never had problems. I drove with it all last winter, dont worry you'll be fine. You'd have to be a complete moron to get engine damage. I mean you'd have to completely submerge the entire filter in water which means you'd have to drive in like a foot of water. I just drove home tonight from work and it was POURING, I mean I could barely see, and i made it fine., and my car is lowered too! The bypass is just way to make more money and it ruins the way the intake looks. save your money and just drive cautiosuly and you'll be fine.
Old Aug 13, 2002
injencivic's Avatar
where can i get one of these bypass valves? thanks for your help
Old Aug 13, 2002
civicvtec1ps's Avatar
Search and Learn
Quote
[hr] where can i get one of these bypass valves? thanks for your help [hr]
always ebay. i saw one for like 50 shipped or so. bypasss i dotn think you really need it i had injen cai but had no problem whatsoever, but if you want to be "safe" go for it. 50 bucks y not?
Old Aug 13, 2002
If the bypass is places inbetween the tubes, do you have to cut anything???
Old Aug 13, 2002
riceboi's Avatar
riceboi is an unknown quantity at this point
i put my valve in about 2 weeks ago and ya, you do have to cut the pipe.
Old Aug 13, 2002
dbone if you just replace the coupler with the bypass valves inbetween the two pipes it should work.
Old Aug 13, 2002
pakman313's Avatar
pakman313 is an unknown quantity at this point
yea i think you do need a bypass valve just in case ya know? my car is dropped 2.5 inches and my cold air intake is pretty close to the ground and i guarentte that when it rains there wil be puddles and water will splash upwards towards the engine, thats what i have experineced, i parked my car in the garge after it rained and my filter was slightly wet, but i guess cuz my car is really low. i just bought a steel cutter thingy from home depot and cut my pipe and just stuck the bypass in it pretty simple.
Civic15
18
Sep 19, 2017 07:48 PM
carid
Nov 7, 2015 01:46 AM
Misfit2613
Jul 30, 2015 09:49 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Theshwartz35
Jul 17, 2015 11:13 PM
