problem......car hesitates
Old Aug 7, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
ok, here is my problem..
when first starting off, in first gear, i usually shift around 2500rpm, recently when i do so, the car seems to hesitate, it burbles as teh rpms rise for a few hundred rpms, and then full power comes right back all of a suden, this also happens in 2nd gear (as i shift into 2nd from first) and the same with 3rd......it is NOT a continuall problem, only sometimes and when it wants to...
i am thinking that maybe the plugs could be fouled....but anyone have any other suggestions?
mark
Old Aug 7, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
<3000rpm=no power in our cars. just shift a little higher, say around 3-3.5k rpm.
Old Aug 7, 2002
Hedonism's Avatar
Hedonism is an unknown quantity at this point
i think its just bogged down, shift at 3000 to 3500
Old Aug 7, 2002
zetaR's Avatar
zetaR is an unknown quantity at this point
Is your A/C on? I've noticed that recently too. I think the A/C just soaks up any power that we might have. I was also thinking about changing my plugs. Plugs is what I would do, especially if you still have the stock ones.
Old Aug 7, 2002
merz's Avatar
merz is an unknown quantity at this point
Could be clogged fuel injectors too - is a stumble or miss of the engine? ... but it does sound like you may be bogging the engine some... shift a bit higher in the revs so the next gear isn't starting too low in the revs to make any power.
Old Aug 7, 2002
theguysmiley's Avatar
theguysmiley is an unknown quantity at this point
If your car hesitates, I'll tell you what it needs.
It needs some good ol'-fashioned COURAGE, BOY!!! That'll help it get up and go!!!
Sorry, I need more sleep
Old Aug 8, 2002
2k12rsx's Avatar
2k12rsx is an unknown quantity at this point
2500 rpms in first? wow...I don't think I ever do that unless i'm in a residential or something. I drive hard 80% of the time i'm in my car so yeah...you might just be bogging down the car with low rpm. How many miles is on it? Fuel injectors like the previous guy said could be it too. Had a tune up lately? I always keep Bosch Platinum in there.
Old Aug 8, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: zetaR
Is your A/C on? I've noticed that recently too. I think the A/C just soaks up any power that we might have. I was also thinking about changing my plugs. Plugs is what I would do, especially if you still have the stock ones.[hr]
The stock plugs are mighty good...no need to change them...remove them..see if they're plugged or fouled first... The a/c does soak up alot of juice too.
also..this happens from first-second.. or enganging first gear?..
winanthony94
Sep 25, 2015 09:05 AM
Skunkone
Sep 24, 2015 04:38 PM
NROD315
Sep 23, 2015 03:46 PM
2005seTO
Aug 30, 2015 10:32 PM
2005seTO
Aug 18, 2015 12:45 PM
