- alternator whine?
- Performance exhaust problem
- DIY: Make speakers sound better!
- Switchin out the parking brake handle. (update with pics)
- 03 Civic Bumper Removal
- need help boosting problems
- Air bag info..
- I-pod...
- Moving Console knobs and buttons...
- OMFG !!! Dont ask how, dont ask why! Just try it on your intake!!!
- Generation years??
- Has anyone tried to make an SRI into a cold air setup?
- can anyone tell me where the pops are that hold in the headliner?
- sanding down paint on intake
- switch power?
- LX Ignitor coils
- Transmission from previous civics?
- Help passing the new PA emissions inspection
- clutch bleeding
- How to remove throttle cable?
- egr valve?
- where's the DIY rear bumper removal?
- Maintenance Required Light?
- HELP!!!.....Apexi VAFC 2 problems
- DIY - VTEC LED - Issues?
- High Pitched Sounds After AEM CAI Install
- opening up altezzas?
- 50 points for finding DIY for Apexi VAFC 2
- Can I do a DIY or do i have to have permission
- Who makes Honda's Electrical Parts..! !Need help ASAP
- SRS Computer Installation ?
- ABS Light On?
- Fuel Pump Fuse
- relayed/door triggered neon setup problem.
- are Ebay pedals any good?
- HELP!!!!! light behind fuel gauge has gone out, how do i fix
- Engine Light Stays on
- hasport
- Water Temp install
- o4 civic header and exhaust
- some ECU wiring quetsions...
- angel eyes color change
- A/T plastic shift panel thingy on center console
- VIS carbon fiber hood
- short shifter?
- MTranny neutral wire?
- my GROUNDING KIT SUCKS!
- ukdm fold in mirrors
- Tips for welding
- help with gauge lighting
- lx/dx headers?
- HELP!! my fuse keeps blowing
- how to do timing
- help
- Upgraded grounding wires fixed my radar detector!
- messed up front end
- alarm receiver question...
- neon wiring (no more cig adapter)
- Carb question
- Make A Fuel Magnet
- AEM Tru-Power Pullies Installation
- Are pedals removable?
- sri to cai
- dounut gasket
- spare tire ring broke
- Disable VALET Mode
- Techies Delight!
- How big of a deal is losing PS???
- Oil Changes
- Problem with indiglo needles.
- manual shifter piece
- how much weight can our car support?
- Shaving Emblems...
- Started car on first gear and e-brake up.
- the oil filter
- Question about Clearing Headlights.
- SRI rubbing throttle cable?
- Revo SS & Stock shifter assembly
- Direct Power System???
- Ex header on Dx engine
- does your RSM work?
- well my ecu is fUXORED. (FRIED)
- k20 help
- Just installed TYC headlights...now my left blinker is out. Need help..please read
- Oh crap, how do I take this apart?
- Need Help.. My fault? or their fault?
- stock air box
- DIY needed for speakers to amp wireing?
- torque specs
- cig lighter wires
- horn stopped working.
- Solution to hot header?
- check engine light that stays on
- Question about head studs
- Help! Somebody
- New Intake Manifold Design
- CEL and air/fuel?
- Octane v. Power
- im depressed and upset...
- Integra Swap Question - 1991
- mounting a tach
- Bad Evo...
- TB ported! PICS/REVIEW (www.maxbore.com)
- turbo problems
- reset maint light?
- clutch
- help out a DX civic owner
- clutch squeaks
- safc hack??
- cutting fenders
- Remove Lighter
- DIY: How to wrap your side control panel in Carbon Fiber Vinyl.
- HELP!! Problem with revo ss (b4 installing)
- vafc installing problem... need some help
- Woah! Has anyone thought about this idea on our cars??
- steering wheel
- Streetglow Idea
- Turning vtec back on with vafc
- Speed meter swap
- Anyone know the screw size for the OEM kit?
- OBX 9006 Hyper white/blues.. will these fit?
- whats the performance increase when adding a cold air intake?
- Exhaust Problem when it rains!!!!
- stalling
- Hyper blinker trouble
- DIY: Glowing gauge cluster
- HP Headers Rattling
- CAI... and high water.. need some help
- auto tranny cooler lines? help
- wet sanding question
- I need help on how to get the front lip off factory hood to install on c/f hood...
- plug & socket jelly/oil/goo; electrical
- '03 Civic EX turns into Christine
- Alarm DIY??
- Crank and Harmonic Damper INFO, very important! | Truehonda
- For those of you with a Xenon kit
- Any way to stop the seatbelt chime in an 04 EX
- A quick question...
- idea for headlights
- DIY Paintin' HeAdLights
- trying to make an AT to paddle shift
- question about my window..
- How can I lower the hood latch so I can shut my C/F Hood?
- 04 ex, 7400 miles, are my shocks bust?
- Different batterys.
- Real Time OBDII Logger
- a/c light not working
- E-Manage.........Gettin a better understanding
- AEM vs Stock compromise
- Anyone ever change the oil in manual trans?
- need more power!
- Water on the driver side floor
- Carbon Fiber Hood Problems . . . Need HELP!!
- Exhaust question
- Door on Dash Removal????????
- Trunk Carpet mold removal
- Who has an intake and has any problems?
- Removing rear bumper (sedan)
- Changing Clutch Fluid
- Intake Filter Question...
- Check Engin
- making a dx vtec
- Headers...it's a standoff.
- how many belts?
- proper throttle cable adjustment?
- Honda Manual
- Making our stock intake cold air?
- which exhaust to choose.
- JET v-force
- RaDio Code.....
- Radiator Cap
- need info on intake
- v-afc hack
- ps2 placement
- A/C Whistling
- simple intake Qs
- superchips or similar
- Tranny Fluid...
- Need a new D17 engine? You can for $53!
- Clear Headlights?
- cd player help
- AHhh..Help..RusT!
- Benefits of bored Throttle Body?
- Alternator Check
- brake help
- shaved door handles
- custom fender flares
- Question About Exhaust In 01+ Civics
- stock fuel pump flow
- *PICS* Look what i found after class
- *PICS* tub of paint vs my civic
- Removing Passenger Front Seat ('04 2dr Ex)
- D17 Gearbox fits older models
- How hard is it....
- Trying to install power door locks.
- wiring gauges
- Weird Question about shift linkage
- dimension question with 03 civic
- stock intake
- rear sway bars for RSX will fit the ex models right?
- how to lower clutch engagement?
- I'm sure most of you have also done this..
- D16 head on D17
- installed gauges and now srs light is on
- i need a lil advice about installing mugen racing seats
- not going past 4000 rpm
- mobil 1 motor oil
- Clutch and FlyWheel!!! need your help
- Quad Bucket Seats.......
- no center console=better shifting?
- a-pillar removal
- H E L P--Engine Maintenance Required Light
- JET's Computer Upgrade
- What part is this?
- fipk question
- 01+ ex tranny question
- Timing Belt Change Problems
- need some ideas and knowledge
- exhaust manifold gasket
- Primary 02 sensor wire on the ECU?
- Overfilled engine oil affect mpg??
- Rear drum adjuster too tight!!!
- relocation:::
- Civic 01' vs 04' rear suspension bounciness!
- sparco 4 point seat install
- just trying
- Help with Header Back Exhaust
- hybrid auto temp in a non electric
- 6 speed trans for d17
- Ok another dumb exhaust question.
- v2 on automatic?
- need help with alarm
- Hey guys....I need the diminsions of a stock wing to install KTR II wing!
- Evaporative Canister Location?
- keyless entry problem???
- header nut size
- 1995 civic service manual website. Close to our car in some areas.
- how to replace the A/C filter?
- Casper 02 SIM question!!!
- 04 sedan fit 04 coupe headlights?
- need help fast
- door lock passenger side
- RSX Base Gauges in civic?
- O2 sensor on the ECU
- Noob Question
- If you have problems with your door lock, ask me.
- Timing belt
- help me :(
- FIre wall question
- Attention Emanage users - new firmware available! V1.39
