how to do timing
Old Jul 29, 2004
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
how to do timing
I have searched around and nothing. I need to know when you time your car do you set the crank pully to the red mark or the white one? I know how to set the cam gear just not sure about the crank pully. which mark is top dead center red or white?
Old Jul 29, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Set the ignition timing to the red mark.
Old Jul 29, 2004
CrewChief's Avatar
what is the white mark for then
Old Jul 29, 2004
Your Parts Guy
If you set it there it will be retarded X amount of degrees. Gotta have the Helms man.
Old Jul 29, 2004
djmota's Avatar
ignition timing would be the red mark the White mark is for TDC This is the one you should line up with for cam timing....make sure it is exact. look at it from a couple of different angles.
Old Aug 5, 2004
CrewChief's Avatar
when you line it up with the white mark and then rotate the engine and then check again its off. but if you line it up on the red mark rotate the engine and check it is lined up on the white. I don't get it.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
DC5@EM2
Bolt-on Engine Performance
Dec 4, 2001 07:53 PM
supercivic01
South
Nov 30, 2001 11:27 AM
