Rear drum adjuster too tight!!!
Old Jul 5, 2004
conspiracy90's Avatar
conspiracy90 is an unknown quantity at this point
There was a recent post on adjusting the rear drum to make the brake pedal a bit firmer. Well i just did that diy and i screwed up! I adjusted it too tight and now i'm having a hard time turning the drum by hand and i guess that when i'll drive the increased friction will overheat the rear brakes. How do i loosen the adjuster screw? I tried to loosen it but it won't go. Any advice?
Old Jul 5, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
MOST rear drum brakes are self-adjusting and should not have to be done manually. to correct this, put the car into reverse, in an open area, and pump your brakes continuously. That should re-adjust them.
Old Jul 5, 2004
tacheon's Avatar
tacheon is on a distinguished road
Automatic drum adjusters do not loosen if it's too tight. The drum adjuster is one-way. It ratchets tigher if there is play. In this case, there is no play, so reverse and brake will do nothing. Also, I don't understand how you adjusted them too tight. You can just back off the star wheel if it's too tight. BTW, I've noticed that people were removing the drum to do this adjustment There is a rubber plug/hole at the backing plate to allow you to adjust without removing the wheel and drum.
Old Jul 5, 2004
I managed to pull it out.
That interesting. I didn't know that. thanks man.
Old Jul 5, 2004
Storm897's Avatar
Storm897 is an unknown quantity at this point
They SHOULD self adjust but they dont. My rear brakes would not have needed adjusting if they self adjusted.
Using the plug in the backing plate is a good idea but I like taking the rear drum off better.
To fix your problem do as follows:
1.) Look at the picture below.
Lightly pull the Clip that engages the starwheel and instead of tightening the starwheel by moving the wheel upwards, move it downwards. This will lossen the starwheel and lossen the shoes. Hope this explains it. If not I'll try explaining in another manner.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
TheRubixHorse
Jul 29, 2015 05:22 AM
DerbyDad03
Jul 27, 2015 11:34 AM
CivicsClass101
Jul 9, 2015 11:14 AM
