angel eyes color change
Old Aug 1, 2004
gotrice's Avatar
gotrice will become famous soon enough
is there a way to change the color of the angel eyes on projector lights? i once had a pair that had the ring a blue color that looked real nice but now that i had to order a new set the ring came in looking white and well you could barely even see it and you cant even tell with the headlights on. so is there a way to change the color or make it brighter at least?
Old Aug 1, 2004
Buy new leds with resistors, open up the lights, and wire them in. They put the crappiest ones in there that don't even last.
Old Aug 1, 2004
IrockCivics's Avatar
is that easy to do?
Old Aug 1, 2004
Sortof. You have to open the headlights like when clearing out the stock ones. An oven works good to loosen the sealent, and then they come apart. Then you just wire some leds in the back of the ring however the stock ones were. You can get power from the parking lights and then connect to a resistor, and then to the led, and then to a ground. If you do multiple leds, make sure there is a resistor in front of each one, or one big one with the sum resistance of all LEDs in the circuit. For blue, it's usually a 560ohm or maybe 460 if you want them brighter.
Old Aug 1, 2004
gotrice's Avatar
where can you find all of this? would a local auto shop have it?
Old Aug 1, 2004
radioshack... or superbrightleds.com I got all my stuff from radioshack.
Old Aug 1, 2004
gotrice's Avatar
have any part numbers? roughly how much for everything?
Old Aug 1, 2004
For me it was alot. $4 for each blue led (2600mcd intensity), and $1 for a pack of four resistors. I had close to 20 leds for my dash. It all depends on how many you wanna stick in the halo. Usually people do 2 per headlight. So it shouldn't cost more than $20 for supplies locally. The website is dirt cheap however.
Old Aug 3, 2004
gotrice's Avatar
they have different type of resistors so which one do i choose from radio shack?
CraigW
May 24, 2015 09:49 AM
Importracer
Nov 17, 2001 03:37 AM
