keyless entry problem???
Old Jul 1, 2004
astrosi's Avatar
astrosi is an unknown quantity at this point
There is a problem with my keyless entry .. can someone help me with them ?
for some reason my keyless control buttom doesn't open/close but if i lock it with the keys then press the arm buttom the horn and the lights go on .. but when i try to unlock it the lights just light up but the locks won't open any one ever had this problem b4
i need help people
Honda getting to my bad side now
Old Jul 2, 2004
streetglower's Avatar
ok, you and everyone else has had this problem. Most likely your door lock actuators are dead. I have had this problem and so have other people. First when you close your doors, and then push the buttom, nothing locks correct? Also if the doors are locked, and you push the buttom, they dont unlock correct? Only way is to use your key, correct? When you are in your car with the door closed, and you push the lock/unlock buttom, what happens? Let me know I will help you with this. What ever you do dont go to the dealer. I will save you money with this.
Old Jul 2, 2004
do you have a SI? or coupe/sedan.
Old Jul 2, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
nuthing with mine....when i installed it everything worked perfectly....proply cuz i bought it used
i didnt even have to code the remote
Old Jul 2, 2004
where did that come from.
Old Jul 3, 2004
astrosi's Avatar
hey thanks StreetGlower its and si .. but i've fixed it .. it was actually the fuse that was blown or dead thats all ..
Old Jul 3, 2004
astrosi's Avatar
topic closed
Youshoe
May 22, 2015 09:36 PM
davidarenberg
May 16, 2015 08:45 AM
Shabba
May 13, 2015 10:55 PM
darwin-t
Apr 18, 2015 09:29 PM
melga
Jan 1, 2002 05:17 PM
