- Any DIY for the clear tail lamp painting...
- quick ? about alarm installation
- questions about a muffler silencer
- Turbo Question - Oil Lines
- What seires tires?
- !.::DIY Front Grille::.!
- A dumb question???
- So put new wheels on, then align or align then put on wheels?
- Please help
- Possible Future: Removing Tranny and so on DIY
- B16A swap from 00 Si to 01 Civic?
- LED's give me hyperblinkers!
- Someone please answer....might be a dumb question.
- DOHC swap for EX's???
- cleaning inside of headlight assembly
- How do I remove the PRNDD3D2 to change color...
- kaminari kit: keep during winter?
- Question about my Angel Eye Projectors!!!!!
- 2002 Civic Altezza install (coupe)
- Type R REAR VALANCE for coupes?!
- Removing the Door Guards on the 4 doors
- SRS Sensors
- 6th and 7th gen radios
- Alarm LED
- Fuel pressure regulator...anybody?
- i need ac
- Help on installing autometer tach
- Type R Kit for Coupes?
- My DIY emblem-removal, LED placement brake thing (vid)
- QUESTIONS ABOUT SWITCHING TO SYNTHETIC.
- Removing rear OEM Lip/skirt
- Why is there an EX header on my LX ??
- sedan and coupe exhausts
- green plug when installing my intake?..wat the?
- soo piss
- neuspeed springs settling
- Throttle Body Question
- low fuel light question...
- AEM cam gear,BAD NEWS!!!
- installing apexi rev meter
- EX, HX, and LX gauge cluster interchangable?
- All Aftermarket springs, front should be rightside up or upside down?
- need diy for prep. a body kit
- OEM header needed for turbo
- Amsoil 5W20...........
- racing mesh
- Nos question
- D.I.Y Shortened Shifter
- injen intake?
- CD Changer Install
- Dash Kit Install
- gotta rotate tires
- How Much to Weld and Fix hole in Rear Trunk?
- installing a switch for neons
- Alarm siren mounting on EX
- No not another ?? about neons
- Replaced my license plate screws...
- EVERYONE READ- ABOUT INTAKES *IMPORTANT*
- Zex kit on 7th gen
- Some questions about intake and exhaust.
- Mobil 1 5W30.........
- clearing the ends
- where to buy new light sockets
- Trunk: spring shocks?
- ATTN: Updated "DIY: No More Trunk Rattle!" with pics to stop the confusion!!!
- Tachometer
- Where to buy???
- How hard is it to?
- Removing CD head unit
- REVO short shifter......
- air bags!!!!!
- power question
- DIY for shift knob?
- 8k services???
- Oil Change?
- Automatic Rpm locked at 5000 rpm
- installing indiglo gauges, wont turn on
- Replace dash lights in 97 civic
- Shaving the head
- removed airbag sticker on visor
- I cut my shifter, and I may have tranny problems will honda cover my warranty still?
- OEM Bra w/ OEM Front lip...
- Question about dying a dash...
- N20 claims another victim!!
- Paint Job!!!!!!
- anyone with a 2" cat-back
- Problem with throttle cable
- Good xenon bulbs
- Anyone ever try this.... Use the OEM KEYLESS ENTRY........
- Honda Part Diagrams?
- i need help puttin inmycorner bulbs...pleeez help
- UPDATED!!!!!..."DIY"- Interior door panels w/ Picts
- screen just came in
- Exhaust Question? Why are there two mufflers?
- REAL ADVICE
- E-brake power wire?
- Is it possible???
- some one help (s-afc)
- ex downpipe on LX?
- Cam's n Pulley's issue!!!!
- AEM Cold Air Intake on 01 Civic LX, BIG PROBLEM..
- Major AEM CAI intake install problem. HELP!!!
- will 2000 civic struts fit
- *sigh* Something else that didnt work
- Question about the suspension of 2k1
- headlight question
- magnaflow exhaust, any problem going over speedbumps?
- anyone know how long your clutch is supposed to last?
- oem alarm cost??
- Suspension problems HELP!!
- for any drag racers out there, help me trouble shoot.
- where to locate singel guage? single pic.....
- exhaust from earlier model civic...
- header torque specs
- intake question
- HELP
- tech Question about the new JDM pistons ive bought!!
- just an idea ??
- Steering alignment off after drop
- instrument gauge and the digital odometer...again
- apex v-afc
- New Muffler, what I have to do first?
- cable disconnected when my car got back from mechanic
- aem pulley question.
- Trying to install windshield wiper LED's...NEED HELP!!
- I'm bored with clear lights...how bout this?
- Bigger battery needed?
- razzi body kit w/ magnaflow exhast
- trim painting ideas!!!!
- need help!
- spark plugs=better gas economy: why?
- noone has ecu diagram????
- Probably a dumb question?
- Chassis Dynometers-G-tech and Blitz Power - INFO?
- whats the Best Sounding exaust for a the civic?
- OEM keyless entry
- Engine Idea!!!
- DIY: Easy change of Dash light color.
- Dc Sports header....
- SETTINGS FOR S-AFC
- measurements of the lower grill
- Need help with sprint drop
- Tach in the LX
- Is my computer f*ckedup.. or do none of the dashligh dyi work?
- from the manual in specs...
- O2 simulator wiring same as 6th gen?
- Aftermarket seats + 3pt. seatbelt, how do u do it?
- anyone has this problem with projectors???
- new idea for changing your interior lighting
- ? concerning clearing headlights
- Body kits .....
- HKS Hiper exhaust question???
- cat back....
- need pic or diagram showing bump stops!
- Help installing Rev/speed meter by Apexi
- question.... plz help....
- Throttle adjustments
- suggestions..
- AEM CAI Q...
- Just an idea..
- Best method for painting the eyelids
- APEXi VAFC wiring illustration question
- hooking up neons
- D16 or D17?
- thinking of making my own side skirts!
- a neons wont work
- Altezza Grill
- OBD-II in civic
- Install: Sparco Steering Wheel, and Racing Harnesses
- Check engine after exhaust installation
- RSXS Sway Bar and some weird noises!!! Help!!!
- problem with fitting on injen CAI help...
- AEM Short Ram Intake
- did i mess up my ignition???
- Rigged Intake with stock intake and K&N filter!! (POST 2)
- srs light?
- help! el gauges won't turn on!
- is it my guages???
- Noob Questions from a senior member....
- 10w- 30 safe to use ??
- pulleys, fuel rail, cam gears
- Oven temp for sedan headlights
- switching over to synthetic
- need help cleared headlights fogged?
- how much to get body kit painted and installed
- Help! Trouble installing lip kit!
- got back from HASport
- header sounds like ass!!!!!
- Door Molding Installation
- Looks like we can have direct port nitrous injection!
- installing taillights
- Fuel safty cut off switch ??????
- Paint window piece
- Zex Products???
- Need Help Painting Piece In Front Of Gauges
- nitrous jets
- Radar Detector, do the cops know we use it?
- Painting interior trim
- 194 bulbs for the front parking lights
- eyelid painting cost?
- Shifter Bushings Install Question?
- 7440 bulb
- StreetGlow Gold Series underbody neons installation advice/help
- pic of my trunk release
- Floor Latch Lock
- Wiring HELP?! Should be simple question...
- Hi! I'm blonde :D
- I need HELP with my projectors!!!!!
- Passing Inspection...........
- need help with installing the type r front lip for the sedan
- aftermarket fog lights question
- Intake install-DON"T LOCK MODS...strange problem!!
- city lights?
- EXACTLY WHY SRI TAKES AWAY POWER, SRI = WASTE OF MONEY.....CAI = GOOD INVESTMENT
- Painting amber bulbs for clear lenses
- Squeaking brake (i think)
- Exhaust
- what to use for drilling?
- how do stop spoiler from becoming loose?
- IAT FOR 2k1 CiviC??
- AEM EMS Pros and Cons for who has this....
- hard downshifting feel (automatic)
- Need Help!... wiring alarm
- Curious: Does the ECU adapt to the type of fuel you're using?
- installing kaminari kit or any lip kit...
- anyone know what kind of computer we have..
- brakes squeeky at 18 k miles
- 2 turbo chargers on a rsx engine
- Painting Altezza Grill???
- Please help w/HID conversion w/zero instructions
- Cat removal on and such
- DC Sports TCS Stainless?
- port & polish q's, plus a throttlebody q
- 1st oil change....
- floor mat screws.
- To anyone with aftermarket Alarm
- Tint Question(The More Responses the Better)
- A/F GUAGE INSTALL
- Help, removing/replacing bulbs in projector headlamps
- MOONROOF QUESTION!!!!!
- Bodykit Fixable?????
- DIY on SRI Intake?????
- ps2 install
- Help me please! I am fixing my car!
- what's wrong with this picture?
- trunk lid mounted tool kit
- DIY: Triple Air Horns /w Dual Compressors
- Highbeam for projectors
- Gas problem simplified
