Oil Change?
Extreme Member
Rep Power: 0 Oil Change?
Hey everyone, I have thinking of changing my own oil from now on. I don't want to pay all that money for someone to do it and have them put some unknown type in my engine, like what I have in it now. First off, I want to use the mobile one with supersyn or whatever it is called. I have about 9,000 miles. Should I use synthetic yet or just keep with the motor oil? Next of all, I need to know what I need. This is what I am pretty sure about needing, a honda oil filter, and a Oil Drain Plug Washer. Do I need the filter wrench to get the filter off? I have no idea what type of filter is on my car, or is the wrench that honda sells just for removing and tightening honda filters? Thanks for all your help!
Rep Power: 0 Do a search. I use mobil one synthetic and a fram ultra guard filter. If the local parts store had a different filter i'd buy it, but thats what they have.
Retired Mod
Rep Power: 0 Link to DIY.... everything you need to know is here (with pictures)
If you can afford synthetic, go for it. I read somewhere that synthetic is for extreme conditions or something...blah I pay $10 to have my oil changed by PURRFECT, using Valvoline oil i think... [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Extreme Member
Rep Power: 0 So what should I go with, synthetic or just oil? That is really all I need to know. I have around 9,000 miles on my car and I do like accelerating fast, if that really makes a difference in what I should use. Please recommend me something, thanks!
Rep Power: 325 Well, first of all, you don't even need a washer. I've been changing oil for over 10 years and never changed a washer in my life. The next thing you need is a Fram Double Guard filter. The one you need is PH-3593A. And you can use sinthetic if you can afford it. I don't see a difference over dino-juice except for the price. I wouldn't pay the extra money for it, but thats me. It's really easy, just remember to check when you remove the old filter so that the old o-ring isn't still there causing a leak. And you shouldn't need a filter wrench. Remember when you tighten to only tighten HAND TIGHT. It won't leak.
Rep Power: 0 I use Amsoil 5w-20 in my car......the 5-20 is what Honda recommends for our cars and Mobil only has 5-30.......I still change my oil at the 5,000 miles Honda recommends......Amsoils even states thats its excellent for 2001- Hondas on the front of the bottle........You can get the exact Honda filter and washers at HandaAccessories.....I'd probably get the wrench at a auto store or Walmart for about $4 instead.....I just started doing my own oil change because I was scared of the crap they were putting in our engines...My car is running so much smoother since I changed over to Amsoil.....[IMG]i/expressions/face-icon-small-smile.gif[/IMG] ..Definate
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Amsoil (53 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Amsoil & Filter.jpg (77 Kb)
El Pinche Turbo Mexicano
Rep Power: 0 i alked to one of the dealership gus on the phone the other day and asked him if the could put syntetic oil nted of my normal oil on the next service and he said no, cause if my car still had warranty they have to pur what ever HOnda gives them or it would void my warranty is this true??? by the way i live in Mexico........
Rep Power: 0 Mobil 1 is great oil... can't go wrong their. ( 5W30 or 0W30 ) also the "first time" you take off the filter it will be tough... if its never been done before or your shop has been doing it, you may need a filter wrench to get it off... but as silverdevil said, "Hand Tight" or as I say sung it up... lol. As for a oil filter I like the OEM Honda filter.
Good Luck...
Good Luck...
Quote
[hr]Originally posted by: Collective
Good Luck...[hr]
Good Luck...[hr]
Rep Power: 0 I think the part number is either ph7317, tg7317, or dg7317 depending on if its regular, tough guard or double guard. I know thats what I can use on my EX.... I am not sure if that part number posted above is right. Next time I change my oil I'm using a spoon sports magnetic drain bolt...
Quote
[hr]Originally posted by: IDQcivic
Next time I change my oil I'm using a spoon sports magnetic drain bolt...[hr]
1 Post
Rep Power: 0 Well, yer engine won't suddenly explode from 10W30, but you should really use 5w30 or 5w20. W stands for winter. I use Motorcraft 5w20 semi-synthetic...same price as dino. I also change every 3000 miles.
DIY King
Rep Power: 395 W stands for winter? I thought it was weight? One is cold viscosity and one is hot viscosity. Something like that...
Anyway, I use Motorcraft synthetic blend from Walmart for $1.77 a quart. Best bang for the buck IMO. I also use Bosch oil filters. Get them! I also use Fram's SureDRAIN. Get it! I will get a remote oil filter kit soon with an oil cooler and thermostat. Get that too! I'll be doing a DIY on that once I have it. Won't be for another 5,000 miles though.
1 Post
Quote
[hr]Originally posted by: RE
The magnetic oil drain bolts don't catch anything. I have one from Pep Boys and the magnetic force feels strong but has not caught any metal shavings. If this actually worked, I would guess that they would come standard in most vehicles. A magnetic transmission drain bolt might work better.[hr]
Quote
Quote
[hr]Originally posted by: Grey
Anyway, I use Motorcraft synthetic blend from Walmart for $1.77 a quart. Best bang for the buck IMO. I also use Bosch oil filters. Get them! I also use Fram's SureDRAIN. Get it! I will get a remote oil filter kit soon with an oil cooler and thermostat. Get that too! I'll be doing a DIY on that once I have it. Won't be for another 5,000 miles though.[hr]
What's a remote oil filter kit?
DIY King
Rep Power: 395 Wow, so many questions...
Just wondering if it's a general fit kind of thing or it there is one specific to our cars.
There's a specific one for our cars. The size is SD2. It has a blue cap. You'll see what I mean when you buy it. Those idiots don't have it listed on their website yet. I guess they don't want the business? Look here: Installed My Fram SureDRAIN
Also, how much did it cost?!
It was like $15 at Walmart.
And the Bosch Filter you're referring to, is it their Standard Oil Filter or Premium Oil Filters and what's the price on those as well?
It's the Premium kind. The part number is 3323. It costs less than $6.
It's used to relocate the position of the oil filter. The oil filter is mounted to the side of the engine. When you take it off some oil spills out each time. It sucks. You need a remote oil filter kit to mount the filter in a more accessible place. Then you can control the oil that will spill out of it. I'm going to use one to install an oil cooler (thermostat controlled) as well.
Rep Power: 0 Thanx for the answers. I guess my last question is how do you dispose of the oil. Does it need to be specially discarded, or do you just run down to your neighborhood sewer and dump it in when ppl arent around?
DIY King
Rep Power: 395 No, save the receipts from when you buy oil and return it to the place you bought it from. They should take it back and dispose of it properly. At least that's what I do. I guess maybe the laws are different for each state, but in my state the law states that they must take it back.
DIY King
Rep Power: 395 You don't have to use the old bottles. You can if that's what you've got. I use empty milk bottles and other clear plastic bottles. That way it's easy to see how much is in the bottle when you fill them up.
Quote
[hr]It's used to relocate the position of the oil filter. The oil filter is mounted to the side of the engine. When you take it off some oil spills out each time. It sucks. You need a remote oil filter kit to mount the filter in a more accessible place. Then you can control the oil that will spill out of it. I'm going to use one to install an oil cooler (thermostat controlled) as well. [hr]
mattdoc
03-14-2017 12:10 PM
BootyDo
05-07-2015 04:46 PM
SoNiCcIvIc
03-11-2002 03:37 PM
