Major AEM CAI intake install problem. HELP!!!
Old Jul 21, 2002
Black02's Avatar
Black02 is an unknown quantity at this point
I went to install my AEM cold air intake on my 02 Civic EX 5 sp today, everything was going great until I made a major mistake. I read in the DIY instuctions to use a 12 x 1.25 nut to mount the bracket for the second pipe near the transmission. Well I had what I thought was a 12x 1.25 nut to mount the bracket on the transmission bolt. I started to tighten the nut onto the transmission bolt and it ended up being the wrong size thread. So, I ended up stripping some of the thread off the transmission bolt. Now, I can't get the correct size nut on the transmission bolt to mount the bracket for the AEM pipe. Needless to say there is no way to mount the AEM pipe bracket now. Would I be able to have this bolt re-threaded? How much would it cost to have a new transmission bolt installed? I really need some advice. Any help would be greatly appreciated. Thanks
Old Jul 21, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
go to a hardware store and explain the situation to the clerk he can help you . you'll need to retap the threads,and obtain a new bolt. you only added five minutes of extra time onto the job don't worry...
Old Jul 21, 2002
mike0404's Avatar
mike0404 is an unknown quantity at this point
Hey..
i've got a big problem with my AEM cold air intake
i just install my aem cai on my 2001 civic lx, 5 speed..
everything was ok, i read all the instraction..everything i did is just like in the instraction..BUT..
after a while (and hour or so) i was driving my car and the problem occure...
when i put on nutral my rpm go down to 0 and my car i ideal...its not happen all the time but my rpm is around 500 and 600 when i'm staing on nutral..
i know that rpm should be 800 when the car is ideal...
what's wrong with it???
NEED HELP.....
maybe the engine gets more air and less fuel.. i dont know..
if anybody knows what's wrong write me at mike0404noga@hotmail.com
Old Jul 21, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
just put a small weld there instead of the bolt.
Old Jul 21, 2002
UNPREDICTABLE's Avatar
UNPREDICTABLE is an unknown quantity at this point
i had used fishing line to harness my intake when i had made some out of pvc piping it came out good but then i later bought a real intake lol!!!![IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 21, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
im kinda clueless as to what the hell people are talking about with transmission braket....and moving it?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jul 21, 2002
Black02's Avatar
Thanks for the responses. Does anyone know what that bolt going to the transmission actually does? Does it go to the mount for the tranny? Just to make sure we are talking about the same bolt, it is the bolt with the pointy end. Where could I go to have the bolt re-thread? Thanks for the help.
Old Jul 22, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
The intake should have come with all necessary hardware to use. I am not sure why you had to use an extra nut??? I have the same intake and everything that came with the kit was used and it worked fine.
Old Jul 22, 2002
Black02's Avatar
An extra nut was recommended in the DIY directions , so that you wouldn't have to unbolt the nut from the transmission.
Old Jul 22, 2002
tummyboy's Avatar
tummyboy is an unknown quantity at this point
well the tranny bracket that I think your speaking of holds the line hydralic line for your cluctch to engage and disengage .. make sure you have the sucker lined up right or you will get a clicking in the pedal when you shift . this happened to me
Old Jul 25, 2002
alienmeatsack's Avatar
alienmeatsack has a spectacular aura aboutalienmeatsack has a spectacular aura about
Quote
[hr]Originally posted by: Notorious
I went to install my AEM cold air intake on my 02 Civic EX 5 sp today, everything was going great until I made a major mistake. I read in the DIY instuctions to use a 12 x 1.25 nut to mount the bracket for the second pipe near the transmission. Well I had what I thought was a 12x 1.25 nut to mount the bracket on the transmission bolt. I started to tighten the nut onto the transmission bolt and it ended up being the wrong size thread. So, I ended up stripping some of the thread off the transmission bolt. Now, I can't get the correct size nut on the transmission bolt to mount the bracket for the AEM pipe. Needless to say there is no way to mount the AEM pipe bracket now. Would I be able to have this bolt re-threaded? How much would it cost to have a new transmission bolt installed? I really need some advice. Any help would be greatly appreciated. Thanks[hr]
The nut I got for mine didn't fit, so I used a hose clamp instead. I just tightened it down till it was just big enough to fit ovver the remaining bolt sticking up and tightened it till it didnt move.
Old Jul 25, 2002
Black02's Avatar
Hey Aleinmeatsack, Thanks for the idea. Does the clamp move at all? Also, how long have you had your intake set up like that? Thanks again.
Old Jul 26, 2002
Quote
Hey Aleinmeatsack, Thanks for the idea. Does the clamp move at all? Also, how long have you had your intake set up like that? Thanks again.[hr]
I think I got the idea here from someone in the forums who had done the same. Made perfect since, and I had an extra hose clamp that was small enough to use. So it worked out for me. (Been a monthish since the install and I have since checked the clamp and it still is holding firm.)
Once I did that, the install was pretty much done... I went back thru and tighted all of the clamps from the throttle body to the middle clamps that hold the 2 pipes together and was done.
I think the whole process took me 45 minutes to do start to finish. I had the stock resonator/filterbox off in no time but took my time on the items I had unhook or unscrew from the engine/tranny to make sure I didnt strip or lose something.
Very easy to install I thought.
Old Jul 26, 2002
Black02's Avatar
Hey aleinmeatsack, Thanks for the help. I'll give it a try this weekend.
Old Jul 27, 2002
CapYoda's Avatar
Escaped Convict
if you have idling problem... make sure u've reset the ECU...
refer to the DIY on installing the CAI on how to do it...
ph0ng
52
Mar 4, 2003 09:15 PM
trevor
Nov 16, 2001 05:02 PM
se7en
Nov 12, 2001 10:13 AM
AB
17
Nov 8, 2001 09:54 PM
godka0s
Bolt-on Engine Performance
Nov 8, 2001 07:16 PM
